Members SheltathaLore Posted December 9, 2017 Members Report Posted December 9, 2017 I'm working on some women's dress shoes (I'm pretty much making things up as I go along. Fun times), and I'm not entirely sure of the best way to execute the straps. The uppers will be made of 2.5 oz kidskin, with a pig suede lining; I assume that to make the straps themselves, I want to layer those together, stitch just inside where the edges should be, then trim the leather to be closer to the stitching. Do I need to reinforce the point where they connect to the uppers with another layer of material? If so, what should I use? (It occurs to me that kevlar for kites might be a reasonable choice for unobtrusive and lightweight reinforcement). Any tips? Quote
Contributing Member fredk Posted December 9, 2017 Contributing Member Report Posted December 9, 2017 I think you've answered yourself remembering back when I did a stint helping at a charity shop, we threw away a lot of decent looking women's shoes only because the ankle strap was ripping away. I reckon a bit of kevlar between the leathers would be the way to go right enough. I'd glue the two leathers for the straps then sew, but not cut too close to the thread when trimming. How close is too close? maybe less than 2mm is too close Quote Al speling misteaks aer all mi own werk..
Members SheltathaLore Posted December 9, 2017 Author Members Report Posted December 9, 2017 Yeah, I had some ideas for how to do it, but I wasn't sure if it was the right way. Thanks for confirming! Everything's better with kevlar :D Quote
Members SheltathaLore Posted December 10, 2017 Author Members Report Posted December 10, 2017 Whoops, actually, I meant Tyvek. It'll still serve the same role, though Quote
RockyAussie Posted December 10, 2017 Report Posted December 10, 2017 On 09/12/2017 at 10:39 AM, SheltathaLore said: I'm working on some women's dress shoes (I'm pretty much making things up as I go along. Fun times), and I'm not entirely sure of the best way to execute the straps. The uppers will be made of 2.5 oz kidskin, with a pig suede lining; I assume that to make the straps themselves, I want to layer those together, stitch just inside where the edges should be, then trim the leather to be closer to the stitching. Do I need to reinforce the point where they connect to the uppers with another layer of material? If so, what should I use? (It occurs to me that kevlar for kites might be a reasonable choice for unobtrusive and lightweight reinforcement). Any tips? I am thinking that the thickness of your straps is a bit thin for that method but I don't know your lining thickness so cant be sure. I mostly only used folded straps when I made them and then lined them in with about 2oz. If you are not using a clicker press knife it will be easier to make the top strap up to width first then attach to a lining that is cut wider (about 1/8" all around then carefully trim up to that after attaching and stitching. A small pair of sharp scissors works well for this also. This is the same procedure whether the strap is folded or not. Trying to cut through both pieces together on a 1/4" to 3/8" strap will be very difficult to get it to stay where you want it while cutting. Most straps tend to break where they go through the buckle in time. Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members SheltathaLore Posted December 10, 2017 Author Members Report Posted December 10, 2017 The lining is about 2oz. Can you describe what you mean by "folded straps"? I'm picturing both sides of a strip folded in toward the middle, but I have no idea if that's what you mean. To be honest, these shoes aren't likely to see heavy wear, but I'd like to figure out the best way to do it anyway. Quote
Members SheltathaLore Posted December 10, 2017 Author Members Report Posted December 10, 2017 I should add that these need to be narrow enough to go through a 3/8" buckle, so I may need to sacrifice some durability. Quote
RockyAussie Posted December 10, 2017 Report Posted December 10, 2017 By folded I mean that the strap folds in from the edges to the middle. Old trick is to make over long to start and put a tack in the end after it has been glued up fully. Carefully with index finger and thumb whilst holding the other end you can get slide them down the strap and close it up. It does take some practice and a folder is generally less of a frustration. For higher quality a tape around 8mm in this case is attached in before or during the folding.Not sure where you would get the tape where you are but over here shoe repair suppliers normally have them. ( square buckles are kinder to the leather wear than the rounded shape ones). Also elastic in the strap that holds the buckle can help with wear as it allows the strap to expand and contract with out over stretching the attachment. Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Members SheltathaLore Posted December 10, 2017 Author Members Report Posted December 10, 2017 All right, I'll give that a shot. It sounds more or like making plain bias tape, but with glue. Any google keywords you can recommend for finding a folder? Where in the strap should the elastic go? I definitely thought about putting elastic there, but if the buckle tongue goes straight through the leather, it seems like that would prevent stretching entirely. Is this is the kind of reinforcement tape you're talking about: http://sorrellnotionsandfindings.com/product/topline-tape/ http://sorrellnotionsandfindings.com/product/backseam-tape/ Quote
RockyAussie Posted December 11, 2017 Report Posted December 11, 2017 14 hours ago, SheltathaLore said: All right, I'll give that a shot. It sounds more or like making plain bias tape, but with glue. Any google keywords you can recommend for finding a folder? Where in the strap should the elastic go? I definitely thought about putting elastic there, but if the buckle tongue goes straight through the leather, it seems like that would prevent stretching entirely. Is this is the kind of reinforcement tape you're talking about: http://sorrellnotionsandfindings.com/product/topline-tape/ http://sorrellnotionsandfindings.com/product/backseam-tape/ Here is an earlier topic that shows a bit on the folder subject . http://leatherworker.net/forum/topic/73224-leather-strap-folding-machine/ Here is a very nice folder that is pretty much the bees knees if ya got the bickies.https://campbell-randall.com/product/model-star-3000 With regards to the elastic You should find examples in dance shoes and in particular ballroom dance shoes for women. Some have just fed the buckle tongue right through the elastic and attached to the shoe upper and some have a leather strip through the buckle and sandwich the elastic between that piece then stitch the elastic to the upper. From memory the elastic unstretched is about 1/2 to 3/4" long. The backseam tape is usually very thin if I remember but neither above is in the width you want. I checked the site and could not find any in the right width for making a 10 mm (3/8") strap. You would be needing a 9mm tape if you were doing a normal folded strap so I had a quick look on the net and found this http://www.textilesleon.com/en/catalogue/adhesive-and-reinforcement-tapes/ Half way down the first page you should see a range of colours at 9mm wide. Sorry I cant help much more at the moment as I am drowning in Christmas orders. Brian Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
