Jason046 Report post Posted January 5, 2018 I am currently using barge contact cement and was wondering if you have to apply it on both sides. I am cementing 2 pieces of leather and the bottom piece is getting the residue. Does anyone know of a solution for this Quote Share this post Link to post Share on other sites
pete Report post Posted January 5, 2018 what is it that you are trying to do????? Quote Share this post Link to post Share on other sites
tzleather Report post Posted January 5, 2018 24 minutes ago, Jason046 said: I am currently using barge contact cement and was wondering if you have to apply it on both sides. I am cementing 2 pieces of leather and the bottom piece is getting the residue. Does anyone know of a solution for this You have to apply the cement on both surface, let them dry and then put them together. Quote Share this post Link to post Share on other sites
Jason046 Report post Posted January 5, 2018 I am gluing 2 pieces of 8 oz leather. The bottom piece sometimes gets on the side that' showing. I have been using fiebings leathercraft cement and would wipe away the excess when it came through but would still occasionally leave a residue. Switched to barge but I guess I'm just going to have to be more careful where it' going. This is the kind of stuff I'm doing Quote Share this post Link to post Share on other sites
fredk Report post Posted January 6, 2018 Try just applying the bare minimum to stick the parts together. It looks like you're stitching them together anyways so the glue only needs to be a small amount. Too much glue; the excess has has to go somewheres, and as you apply it to the top of the surface the excess goes into the leather and out the other side Quote Share this post Link to post Share on other sites
Mark842 Report post Posted January 6, 2018 These work great....don't have to get them from tandy, just google glue eraser. They will quickly and easily remove the glue. https://www.tandyleather.com/en/product/heavy-duty-adhesive-eraser Quote Share this post Link to post Share on other sites
Jason046 Report post Posted January 6, 2018 Nice, thanks Mark I will check that out Quote Share this post Link to post Share on other sites
