Members MarkCdub Posted February 10, 2018 Members Report Posted February 10, 2018 Im using fiebings pro dye's, and I cant seem to get a finish that doesn't look streaky. I can tell the streaks are where I reload the dauber and I overlap a strip of what I have already done. Do I need to use a circular pattern when applying dye? Quote
bikermutt07 Posted February 10, 2018 Report Posted February 10, 2018 (edited) A circular pattern will help. A lot of folks opt for a larger applicator when doing larger pieces. A piece of sponge or shearling are good options. Also, after you buff and apply some neetsfoot oil the dye tends to blend together a little more. If you look closely a lot of pieces shown on this site have some degree of variation in the dying. Another technique ( I haven't tried) is block dying. Take a large block and wrap it in an old t shirt. Dip that into a pan of dye. Then take it across the whole piece at the same time. Edited February 10, 2018 by bikermutt07 Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members MarkCdub Posted February 10, 2018 Author Members Report Posted February 10, 2018 I saw a video where the guy had a big tub and just dipped the leather into it. That came out clean, but he also had a gallon jug of dye. I suppose I need to let it dry a little while. Its just a good thing that the part thst is streaked will not be visible. Quote
Contributing Member fredk Posted February 10, 2018 Contributing Member Report Posted February 10, 2018 For large areas I dampen the leather and apply dye with a sponge about 3 x 4 inches. I apply in a few straight strokes then go over it using circular For medium sized item I dip dye. I use a stainless steel oven baking tray. I dilute the dye about 2 alcohol to 1 dye Quote Al speling misteaks aer all mi own werk..
bikermutt07 Posted February 10, 2018 Report Posted February 10, 2018 20 minutes ago, fredk said: For large areas I dampen the leather and apply dye with a sponge about 3 x 4 inches. I apply in a few straight strokes then go over it using circular For medium sized item I dip dye. I use a stainless steel oven baking tray. I dilute the dye about 2 alcohol to 1 dye Listen to @fredk, according to another post he has been at this a long long time. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members Halitech Posted February 10, 2018 Members Report Posted February 10, 2018 A lot of times I'll do the initial application using a 2" foam brush in a circular motion. Once everything is covered, I then do a heavy application in a straight line. let it dry then buff like mad. Usually end up with very minimal streaking that way Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members Mattsbagger Posted February 10, 2018 Members Report Posted February 10, 2018 I've switched to an airbrush because I didn't have luck either dip or wipe dyeing. Quote
Contributing Member fredk Posted February 10, 2018 Contributing Member Report Posted February 10, 2018 1 hour ago, bikermutt07 said: Listen to @fredk, according to another post he has been at this a long long time. Not that long ole chap. Only about 18 years I found that normally dry leather absorbs the dye unevenly. By dampening the leather, not too wet, the water helps the dye spread thru the leather giving it a more even absorption, I make sure my sponge is not dripping wet with the dye as well as if it is the first part you touch will get the most dye and the rest of the leather will get a minimal amount. A sponge wetted with dye then squeezed out applies dye more evenly I use Fieblings dye which I dilute with methylated spirits [alcohol] Quote Al speling misteaks aer all mi own werk..
bikermutt07 Posted February 10, 2018 Report Posted February 10, 2018 13 minutes ago, fredk said: Not that long ole chap. Only about 18 years I found that normally dry leather absorbs the dye unevenly. By dampening the leather, not too wet, the water helps the dye spread thru the leather giving it a more even absorption, I make sure my sponge is not dripping wet with the dye as well as if it is the first part you touch will get the most dye and the rest of the leather will get a minimal amount. A sponge wetted with dye then squeezed out applies dye more evenly I use Fieblings dye which I dilute with methylated spirits [alcohol] Thanks Fred. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members MarkCdub Posted February 11, 2018 Author Members Report Posted February 11, 2018 Wow, bunch of great information. Thank you. Does diluting the dye make it lighter and therefore give you more time/control to get the desired color and coverage? Quote
