Members Nuttish Posted March 1, 2018 Members Report Posted March 1, 2018 On 2/23/2018 at 0:26 PM, viktor said: Thank you guys, very helpful. In your opinion, does the double stitching affect the aesthetics of the final product if they are placed in the middle of a belt? Not to anyone who knows what they're buying because it's in the nature of the technique. As someone said below, longer runs of linen thread will break. They also untwist and pick up dirt and dye. A good coping strategy is to use no more thread between two needles than you can put through your first hole and comfortably pull and tighten without stretching your arms too much. The thread closer to your needles will show more and more wear as you work. Just start a new one when you get to a point where the old one looks cruddy or is breaking at the needle eye. I'm looking at several instances of new threads started in the middle of a run on an old luxury French calf duffle bag. If anything, it's evidence that someone made this thing entirely by hand. Quote
Contributing Member fredk Posted March 2, 2018 Contributing Member Report Posted March 2, 2018 I was ignoring this topic until now. When I'm sewing - all by hand - I'm too busy to count stitches. I thunked me a think and its surprising just how many stitches I'd do in a run. Not 800, but maybe 400 or so. -or sew? So 600, 700, 800 could be achieved quickly without realising it I only make bags with gussets. I usually sew the front of a bag to the gusset first then the gusset/front to the back. Usually I use a linen/ploymer pre-waxed thread. Most times I use a separate thread for front and back sewing but on occasion have used a single length. By my maths. Assume I make a bag 9 inches across by 7 inches high. I sew at 3mm, but we'll convert that to 3.175= 1/8 inch for this maths. That 8 stitches per inch. so the first sum is 8x (7 + 9 + 7) = 184. And as I do a saddle stitch thats x2 = 368, and if I use the one length for front and back thats x 2 again = 736 stitches approximately Lets take a 40 inch belt saddle stitched at 8 per, thats (8 x 40) x 2 = 320 x 2 = 640 stitches. Even at 5 per its still 400 stitches. Down one side. Its feasible to start sewing at the buckle end to the tip and back up to the buckle in one sewing, so that makes it 1280 and 800 stitches approximately Soon adds up to a lot of stitching On other points; I always cut more thread than I reckon I'll need. The thread is the cheapest part of your work. Even tho my thread is pre-waxed I wax the thread before and at regular sewing time intervals. The part attached to the needles soon shows wear, when it gets too bad I cut off the needles and some worn thread and re-attach the needles and continue. I've learnt that the key to keep it going smoothly is to wax the thread well and often. But I'm still trying to get a beeswax mix at the right stickiness and softness/hardness for sewing. Never yet had to make a join in a sewing due to thread breakage or lack of thread Quote Al speling misteaks aer all mi own werk..
Members Matt S Posted March 2, 2018 Members Report Posted March 2, 2018 I have found that using very long thread (much more than one fathom per needle) is very awkward and slow. I prefer linen and as others have noted there are wear and dirt issues. Further I find the inevitable tangles very tiresome to sort out. One way of avoiding this doing a long stitching run with a single (well, two single) lengths of thread is to start in the middle. No, I've not been spray painting in the cupboard again. Take a belt as an example. Estimate how much thread you'd need to complete it. Cut two lengths and put needles on em. Then find the middle of the seam (in this case the point). Stab with the awl and pull both threads through until their middle. Identify which is which and bundle up one side with a rubber band. Sew up the free end, then flip over with the bundled side. Quote
Members billybopp Posted March 3, 2018 Members Report Posted March 3, 2018 19 hours ago, fredk said: I was ignoring this topic until now. When I'm sewing - all by hand - I'm too busy to count stitches. I thunked me a think and its surprising just how many stitches I'd do in a run. Not 800, but maybe 400 or so. -or sew? So 600, 700, 800 could be achieved quickly without realising it I only make bags with gussets. I usually sew the front of a bag to the gusset first then the gusset/front to the back. Usually I use a linen/ploymer pre-waxed thread. Most times I use a separate thread for front and back sewing but on occasion have used a single length. By my maths. Assume I make a bag 9 inches across by 7 inches high. I sew at 3mm, but we'll convert that to 3.175= 1/8 inch for this maths. That 8 stitches per inch. so the first sum is 8x (7 + 9 + 7) = 184. And as I do a saddle stitch thats x2 = 368, and if I use the one length for front and back thats x 2 again = 736 stitches approximately Lets take a 40 inch belt saddle stitched at 8 per, thats (8 x 40) x 2 = 320 x 2 = 640 stitches. Even at 5 per its still 400 stitches. Down one side. Its feasible to start sewing at the buckle end to the tip and back up to the buckle in one sewing, so that makes it 1280 and 800 stitches approximately Soon adds up to a lot of stitching On other points; I always cut more thread than I reckon I'll need. The thread is the cheapest part of your work. Even tho my thread is pre-waxed I wax the thread before and at regular sewing time intervals. The part attached to the needles soon shows wear, when it gets too bad I cut off the needles and some worn thread and re-attach the needles and continue. I've learnt that the key to keep it going smoothly is to wax the thread well and often. But I'm still trying to get a beeswax mix at the right stickiness and softness/hardness for sewing. Never yet had to make a join in a sewing due to thread breakage or lack of thread I think that if I ever tried to count or calculate the number of stitches in an item, I'd never hand sew again. LOL. But, that said it eventually gets easier, faster, and even relaxing - you can listen to music or even watch some TV while you work. It's a lot like driving a car. Remember when you first started driving? It took ALL of your concentration every time you went for a drive. If you tried to change the radio station, you were likely to swerve all over the road. But, as time went by and you got more experience, you could relax a bit and sing along with the radio, change stations with ease. It all got easier and more automatic - you still pay attention to what you're doing but it's just not occupying your entire brain until you get to the tricky curve. You get to that point with hand sewing too, and it can be enjoyable! - Bill Quote
