Pirate305
Buffing, Buffing, buffing??
Okay I know I have to buff the leather after dying, but it seems the dye never stops coming off. Am I doing something wrong? should I be using a machine? What should I use to do the buffing? Any input would help.
Thanks
Thanks
I typically give it a once over after dying then apply finish and then buff for real...
p.s. i use the synthetic wool pads, an old piece of jeans, a t-shirt etc, whatever i have nearby but almost always go over it last with a wool pad.
Edited by koreric75
added info
What dye are you using?
A wool pad?! What kind, size etc.
right now I'm trying Angelus in coffee and oxblood, and it comes off after buffing for 20 minutes. I have also used Fiebings and the same thing happens. especially if I use water. I have tried wiping with acetone and alcohol and I'm still buffing and dye is coming off.
I'm not familiar with the Angelus, but I use the fiebings all the time. Give it a good 24 hours to dry after you dye it. Then you buff it dry. Don't add anything wet to it. No water, acetone, or alcohol. Then you can add the conditioner you want. I use neetsfoot oil. Give that 24 hours to penetrate. Then add your finish.
Good luck.
Like these, i get them from tandy but you can  find them other  places...
Not been asked yet; what type of leather is it and how did you prepare it for the dyeing?
The leather is Veg tan 2/3oz or 3/4oz. I wipe it down with either denatured alcohol or Acetone.
In my experience, Angelus dyes behave about identically to Fiebings spirit dyes -- they just have the advantage of being legal in California, where you can't get Fiebings without making a road trip to Reno. XD
Certain colors are worse than others.  Browns and red should be fine.  Blue/green/purple are the worst with USMC black being the king of rub off.  I use sheep fleece but in bigger sizes to facilitate buffing.  As mentioned earlier, letting it dry completely helps tons.
Try waiting 24 hours before buffing.  Did you say you are buffing for 20 minutes, or are waiting to buff 20 minutes?  I've never buffed anything for more than a minute or so and I've never had issues like you describe.  I've tried applying Neatsfoot oil first and then dye, dye straight over clean leather and not having issues.  I typically use Fiebings Pro oil dye.
Sounds like another reason to add to the 90 reasons to not live there.
Thats the trick. Had the same issue with Fiebings Leather dye, you rub like your life depends on it but it wont stop coming off. Once died a front of a bag and covered a whole t-shirt in dye excess. What I now do is this:
use Fiebings Professional Oil Dye: you can dilute them with denat. alcohol the same as the leather dye. The name is confusing, its also alcohol based, the color particles are made from petroleum thus the name oil dye
wait at least 12 hours
buff once
I oil my pieces after I dyed them if necessary, let the oil sink in until dry to the touch, buff them again, next to nothing coming off now. The oil evens out the color too, thats a nice side effect
finish it and give it a final rub after a few hours of drying.
Upon delivery I apply some leather treatment to make it smooth and shiny again. Works every time now
buff once
I've had good luck with carnauba creme as a finish on many items.  For things that I want to shine, I use Supersheen from Tandy.  It provides a nice, durable finish.  There have been a couple of items I experimented on and used a neutral shoe wax and actually found it had good results.
Buffing excessively will remove the top surface on most things as you are just rubbing it away
All you want to do after giving it about 24 hours to fully dry is buff it for a couple of minutes totake of any loose dye that may be sitting on the surface to leave a smooth surface for finish
Kind of an odd final step but I use good old shoe polish a dauber and a brush for a super finish. I just finished a product died USMC Black and it looks spectacular. Took off the EXCESS by buffing and then a coat of Aussie and then dry/absorb time, spray wax and the shoe shine.
This was one of a dozen pieces made from drum dyed but I screwed up the edging on one in natural and had to dye the whole thing black. Looks the best of the batch.
Bob
Interesting that some of you apply neatsfoot after dying, I was taught to oil it, wait 24 hours, then dye (and use Fiebing's Pro-not-called-Oil-anymore Dye). I rub it down with an old T-shirt for a couple minutes before applying the finish coat. Oiling it first helps draw the pigment deeper into the leather.
I guess it depends on what you aim for. I agree with you, when you want your dye to soak deeper into the leather it is useful to oil it before dyeing. My purpose is usually to re-smooth the leather after it was dyed, which makes it stiff (and curly when using thin leathers). I found that a good coat of neatsfoot oil smoothens the leather and partly reverts the curling of thin leather. Sometimes I even oil right after dyeing thus preventing or lessening the stiffing/curling of the leather, especially when dyeing both sides of the (thin) leather. Didn't achieve the same result when oiling it before dyeing but maybe I was doing it wrong...
Just my personal experience, but if someone has a better approach I'm willing to give it a shot.
Angelus dyes are so juicy because they have a ton of pigment. I absolutely love their jet black but unless you cut it some you will be buffing until your eyes bleed. Even their cordovan requires a bit more work than Fiebings cordovan but I like the color better. I have no problem with Mahogany and brandy though so its color specific and not all angelus dyes are a pain.
Here is my 2 cents and worth about that much
Leave your piece alone after dying at very least overnight.
I did not have the same success cutting Angelus dye with denatured that I did with fiebings so for me it was worth it to buy the Angelus reducer for the colors that need it like the jet black.
Use a throw away rag as your first couple of passes. I keep all my old tee shirts and such and have a container of them in the shed. Soil one up toss it and then use another. My wonderful wife cuts them into smaller pieces for me.
You can final step with the sheep's wool and tandy sells a fair sized bag of remnants for cheap. I still have some from the last bag I bought months ago.
https://www.tandyleather.com/en/product/sheepwool-remnants-4-oz
Interesting -- what did the denatured alcohol do that wasn't working?
I've been cutting Angelus dyes with 91% isopropyl alcohol when mixing small batches, and acetone for the big batches I use for dip-dyeing. Acetone was what I'd seen recommended on Angelus's website at one point, but it is just so caustic, eats through my gloves and makes me nervous about what it's doing to the leather, and I'm like Angelus whyyyyyy. D: I'd been planning to try denatured alcohol instead next time I mixed up a batch -- glad I caught your comment before I did! But I'm curious about how denatured alcohol vs the Angelus reducer behaved differently?
