DonInReno Posted April 1, 2018 Report Posted April 1, 2018 While many/most can't imagine anything other than a heavy cast iron sewing machine pedal with a tiny range of motion, I spend more time driving than sewing and more than once I've wished for the feel of an automotive version. The frame I'm working on now has a square tube in the right place for a pedal intended for hot rods....so here's a new toy - stainless steel and about $35 from Summit Racing. Mounted under the tube requires the linkage to push up rather pull down, but that's simply a matter of turning the servo controller speed input upside down. Quote
garypl Posted April 1, 2018 Report Posted April 1, 2018 That is pretty cool! Tell us how well it works when you finish installing it. Gary Quote
Members dikman Posted April 1, 2018 Members Report Posted April 1, 2018 You going to fit one of them thar racing pedals with holes in it? You know, to make it go faster? Quote
DonInReno Posted April 2, 2018 Author Report Posted April 2, 2018 It's kind of funny that the "fastest" pedals for drag cars and boats looks the most like an aluminum commercial sewing machine pedal! It's good for all the way on or all the way off. Lol I'm such a slow sewer - even on long canvas seams - that there's no need for racing stripes so far. Quote
Members Darren Brosowski Posted April 14, 2018 Members Report Posted April 14, 2018 I am making remote foot pedals for "portable" machines using a servo and that pedal you have shown us will make them lighter and prettier. Thank you Sir!! Quote
DonInReno Posted April 14, 2018 Author Report Posted April 14, 2018 Nice! Here's a pic showing the simple splined pivot allowing the foot pedal and arm to be adjusted to any angle relative to each other. JEGS probably has a similar variety of this style of pedal in various forms - there just happens to be a Sumit Racing warehouse in Reno. Quote
Members Darren Brosowski Posted April 14, 2018 Members Report Posted April 14, 2018 I have just found a supplier in Australia for them. $AU35 + $8 postage. Quote
DonInReno Posted June 9, 2018 Author Report Posted June 9, 2018 Gas pedal is two-thumbs-up! There is about a 4:1 ratio of pedal movement to shaft movement and most of the variability is in the first 1/2" of the 2-1/2" of pedal travel, which seems about right. Surprisingly, the amount of return spring pressure greatly affects the comfort of your foot. Too little is as bad as too much. With just the factory return spring the resistance is so light a single big toe can easily operate it. The bracket that uses factory motor mounting holes was tossed and the speed controller was mounted separately from the motor, which was flopped around and now runs in reverse - super simple - time to mount the planetary reducer. Tomorrow I'm grabbing another pedal and making it into the presser foot lifter! Quote
Members Bugstruck Posted June 9, 2018 Members Report Posted June 9, 2018 Heim joint linkage made me grin. Slick. Planetary Quote
