garypl Posted April 21, 2018 Report Posted April 21, 2018 Here is an article on the arbor press mods - search for this topic Snaps/rivets/makers mark...press to use? Quote Cowboy 4500, Consew 206RB-4
Members Gabriel Rasa Posted April 21, 2018 Author Members Report Posted April 21, 2018 (edited) 5 minutes ago, garypl said: Here is an article on the arbor press mods - search for this topic Snaps/rivets/makers mark...press to use? Ohhhh yes, that is *exactly* what I've been needing. Thanks! ...Except I can't find the thread you're talking about? Edited April 21, 2018 by Gabriel Rasa Quote
garypl Posted April 21, 2018 Report Posted April 21, 2018 11 minutes ago, Gabriel Rasa said: Ohhhh yes, that is *exactly* what I've been needing. Thanks! ...Except I can't find the thread you're talking about? It’s in the How Do I Do That forum - thread started June 28, 2016 by Double Daddy. There probably is a way to copy the link, but I don’t know how to do that - sorry! Quote Cowboy 4500, Consew 206RB-4
Members Gabriel Rasa Posted April 21, 2018 Author Members Report Posted April 21, 2018 14 minutes ago, garypl said: It’s in the How Do I Do That forum - thread started June 28, 2016 by Double Daddy. There probably is a way to copy the link, but I don’t know how to do that - sorry! Found it! Though for some reason it wasn't coming up when I tried to search for the keywords in the title. o_O It looks like an undertaking, but one that would be well worth it when it's done. I admit I'm a bit daunted because I've done very little work with metal before (apartment living for the past 15 years, puts a crimp on the power tools) -- how do you drill the holes into the ram? Can you use a regular power drill for that? Does it need special drill bits? Quote
Contributing Member fredk Posted April 21, 2018 Contributing Member Report Posted April 21, 2018 Centre punch. Standard drill with HSS drill. Use a very slow speed and a cooling/cutting fliud. There are special fliuds but in the past I've used 3-in-1 oil, brake fluid and engine oil - both new and very used. You can drill once to size or start small and work up the size in a few size steps. Best to use a drill stand for accuracy, but if you're very careful it can be done without Quote Al speling misteaks aer all mi own werk..
garypl Posted April 21, 2018 Report Posted April 21, 2018 9 minutes ago, fredk said: Centre punch. Standard drill with HSS drill. Use a very slow speed and a cooling/cutting fliud. There are special fliuds but in the past I've used 3-in-1 oil, brake fluid and engine oil - both new and very used. You can drill once to size or start small and work up the size in a few size steps. Best to use a drill stand for accuracy, but if you're very careful it can be done without Like Fred said - I used my drill press and a cross vise to hold the ram straight. I drilled using a 3/8” twist drill - not that hard if you take your time. If you can find a small machine shop nearby you could have them do it and hopefully they will charge a reasonable price! Gary Quote Cowboy 4500, Consew 206RB-4
Contributing Member JLSleather Posted April 21, 2018 Contributing Member Report Posted April 21, 2018 2 hours ago, Gabriel Rasa said: I'm not clear on how to attach dies/stamps/etc to it though? It's just got a flat piece of metal in there now, and no visible way to screw or slot attachments to it. I might have misunderstood -- I thought you were talking about cutting out the SHAPE. That would require a "clicker" die, or what some the old folks might have called a "cookie cutter". Like this... These were made to quickly cut out parts for magazine pouches (gun clips). What you describe would be smaller than these, but same idea. With the type of press you have, set the leather in place, then set the die on top of the leather, then a metal plate OVER the die for the ram to come down on to press it down. Note you should have a cutting board under the leather to protect the die cutting edge. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Gabriel Rasa Posted April 21, 2018 Author Members Report Posted April 21, 2018 Just now, JLSleather said: I might have misunderstood -- I thought you were talking about cutting out the SHAPE. That would require a "clicker" die, or what some the old folks might have called a "cookie cutter". Like this... You didn't misunderstand, the conversation just wandered over to die presses, because that's something else I'm interested in. The clicker looks handy, though I don't actually make the shield things often enough to merit one. I take it that's a different machine altogether, not an attachment you can put on an arbor press? 59 minutes ago, fredk said: Centre punch. Standard drill with HSS drill. Use a very slow speed and a cooling/cutting fliud. There are special fliuds but in the past I've used 3-in-1 oil, brake fluid and engine oil - both new and very used. You can drill once to size or start small and work up the size in a few size steps. Best to use a drill stand for accuracy, but if you're very careful it can be done without GREAT info! Thank you so much! Quote
Members billybopp Posted April 21, 2018 Members Report Posted April 21, 2018 For something as small as these shield tabs, you probably could adapt an arbor press to do the job, but it probably wouldn't readily go larger. It'd take some metalworking skill, (yours or somebody elses ) tho to make a flat plate for the bottom of the ram and a flat plate for the base with cutting board material over it. - Bill Quote
Contributing Member fredk Posted April 21, 2018 Contributing Member Report Posted April 21, 2018 Know anybody wot can weld? Weld a 3/8 bolt to a piece of 3mm or 6mm steel plate. I bought a bit of 3mm steel plate recently for my press, cost me all of £1.60 [about $2] Buy a piece of 6mm to 12mm thick acetal. Use two-part epoxy glue to stick it to another piece of steel plate. Acetal, about $5, steel plate, another $2. At most about $15 for it all Quote Al speling misteaks aer all mi own werk..
