JHayek Report post Posted April 21, 2018 I have an american 6 inch crank slitter that has a broken handle. Can anyone recommend a source for replacement parts for this machine? Thanks Quote Share this post Link to post Share on other sites
Sonydaze Report post Posted April 21, 2018 I hope someone will prove me wrong, but I don't think parts have been available for a long time. If the shaft is the same size, you may be able to get a handle for a Landis model 30... they are very simular (and use the same blade). Quote Share this post Link to post Share on other sites
Webicons Report post Posted April 21, 2018 Which “handle” are you referring to? The crank handle on my American was definitely replaced with a home made one. Just looks like a flat stock of steel with a bolt welded onto one end (to fit on the body) with a set screw and a leather wrapped handle on the other end. Many machine shop could make one. If you’re taking about the adjustment handle then that’s going to be a tough one. Quote Share this post Link to post Share on other sites
Ken Nelson Report post Posted April 21, 2018 some old crank meat grinder handles will work. As said, not h;ard to make if looks are not important. Quote Share this post Link to post Share on other sites
JHayek Report post Posted April 22, 2018 I need the adjustment handle. I have considered a machine shop but was hoping to avoid the hassle and expense. I am aware new parts may be non existent but was hoping to locate someone who deals in this equipment that may have old parts or even a handle for a pattern Quote Share this post Link to post Share on other sites
Webicons Report post Posted April 22, 2018 (edited) That piece looks like cast iron. If you don’t have the pieces to braze together then I figure the best/easiest way to recreate this piece would be through a lost wax process. Using the piece that you have, you can build upon it with clay or similar, cast in 2 part RTV, make a wax positive, encase in fine sand and pour molten steel or brass. Refine shape with Dremel or files. Definitely a project. Edited April 22, 2018 by Webicons Quote Share this post Link to post Share on other sites
Sonydaze Report post Posted April 22, 2018 I too assumed that it was the crank handle.... the Landis 30 is not the same there. I have the American model LS440 (the model number is on the lower backside of the body). If you like, I can take some pictures and a tracing of the adjusting handle. If you get it machined out of aluminum, the cost shouldn't be overly expensive. These machines seem to sell for $600 - $1000, so it is likely worth fixing. Quote Share this post Link to post Share on other sites
JHayek Report post Posted April 27, 2018 Sorry for the delayed response...pictures wit measurements would be very helpful and much appreciated. Please don't go to any trouble or disassemble your splitter though. Quote Share this post Link to post Share on other sites
bgentle Report post Posted September 22, 2023 Did you ever get the info you were asking for? I need a handle as well. Quote Share this post Link to post Share on other sites
glamb Report post Posted April 16, 2024 Buy a file handle and drill a hole through it length wise, Bolton. Quote Share this post Link to post Share on other sites
Tastech Report post Posted April 16, 2024 A few years ago i did a repair on a similar machine . I used a handle from an old meat grinder ( meat mincer) . I had to drill it to size and drill and tap a grub screw to lock it to the shaft. Over all it was quite easy . If i see an old meat grinder at a yard sale going for next to nothing i buy it just so i have a few handles as spare parts . Note , most meat grinders have a square hole in the handle so take a measurement of your shaft and make sure the round hole you have to drill is compatible. Also take a measurement of the overall length of the original handle and find one that is close . Quote Share this post Link to post Share on other sites
