It depends on personal choice. Some use say 8 or 9 stitches per inch. Lay your chisel on a ruler and see how many points fit in a inch. Gives a rough estimate of SPI. I am out of time so I don’t have access to my tools to take pics to illustrate what I am talking about. Different SPI will give the same project that is exactly the same a completely different look.
21 minutes ago, kyrrk said:
What about the stitching you were saying? I only have 4mm pricking iron, uhm what do I need to use for wallets? What do you mean by a bit big?
Edited by Mattsbagger
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
1 minute ago, Tugadude said:
Your stitching looks great.  I was simply noting that the thread is large in comparison to many wallets I see.  I actually like the look.  However, some folks will feel it is a bit large, or what is sometimes called "chunky".
Regarding edge coat, it is an acquired skill like anything else.  Once you get the technique down, it actually becomes very easy to do.  The trick is getting the proper tool, learning how much Edge Kote to apply and a steady hand.  You almost have to have guts to do it right.  You have worked hard on the project and don't want to ruin it, so you maybe skimp on the amount of Edge Kote you apply and it just doesn't work well that way.
Practice on some scrap.  And if a little runs over the edge, just wipe it off immediately.  A couple of recommended tools are a metal spatula as offered by Tandy, a roller applicator also through Tandy and a common pencil.  Personally, I use flat, wooden stir sticks intended for stirring coffee and they work great for me.  When I'm done, I just wipe them down and re-use.
Ok I got your point. It's simply because it's the only resource I have other than 0.8mm thread. Here in my area it's very difficult to find tools and supplies, I rely on the internet but some supplies are so expensive.
Oh thank you for the tip, although I bought a roller and still find it difficult, but maybe just needs practice . Thank you again for the advice :)
You will find that there are sometimes "rules of thumb" or "conventional" ways of doing things.  Small items usually demand more stitches per inch and smaller thread diameters.  The idea is to keep the proportion of the stitching consistent with the size of the article.  However, you can certainly take license to change that up to achieve a particular look or aesthetic.  I did that on a watch strap that was made out of a repurposed baseball glove.  I just felt the glove leather wanted beefy stitching and so I used 1mm braided waxed polyester thread and was happy with the result.
For only a year in the craft, you should be proud of your stitching!
5 minutes ago, Mattsbagger said:
Thank you for the information provided. I appreciate your help. I'll be more aware of that now. :D
9 minutes ago, Mattsbagger said:
Some great pictures in that link.  Even with the same iron you can achieve different looks.  Notice how some of the smaller thread helps accentuate the slanted, or zig-zag look.  Changing the teeth per inch on the iron and the size of thread gives you many possibilities.
But again, I think your stitching is fine.
@Tugadude
It's interesting, I'll be making watch strap soon. I ordered some watch buckle, I want to try to make them.
Sometimes I love my stitching, sometimes I think I need to improve it. I'm not so sure if my saddle stitch is right. Hmm
BTW, your overall skills are quite good also.  The cut of the pockets, the zipper, all look very clean.  Well presented work.
