I'm curious is there is any difference in torque with the Techsew speed  reducer being a 6" pulley and the SR-2 speed  reducer being  9"?    Any help is appreciated!
Edited by Jflip2018
The unit that gives you the greatest reduction will produce the most torque. All other variables being equal.
  On 5/22/2018 at 3:48 AM, Jflip2018 said:
Thanks, I guess I should have added that both reducers will get me to 1/3 ratio.  The only difference is the size of the pulleys.
Expand
I don't understand how both will get you to 3-1?... Unless you have different pulleys for the drive motor or machine.
Machines currently in use: Cowboy 3200, Adler 67-372, Singer 66, Singer 15-91
Gotcha, I'm tracking on the different sizes on the same pulley, but I don't see how that matters unless you factor the motor pulley and machine handwheel pulley... Torque wise..
Like @bullmoosepaddles stated all other variables remaining constant the larger pulley should give you the slower speed, higher torque, which was your original question, right?
For Max torque I'd venture a small motor pulley to the 9"speed reducer pulley then to a larger or equal size handwheel pulley.... Depending on the machine's pulley if there is a large Delta in price between the two you could go small motor pulley, 6" reducer pulley provided the handwheel pulley is large enough it you can reduce the size of the motor pulley enough to get to the same speed/torque as the 9"speed reducer.
  • 4 weeks later...
TechSew has a speed reducer which is 154 CND which interestingly enough is more than half the cost of the servo motor and is just passive metal parts. I think buying parts and making one is a more cost effective way to go for me.
"Oh my God....I beseech thee grant me the grace to remain in Thy Presence; and to this end do Thou prosper me with Thy assistance, receive all my works, and possess all my affections" Brother Lawrence c.1614-1691
plinkercases.ca
One advantage to larger pulleys, given identical reduction, is better traction on the belt - so belt tension isn't as critical.
