RockyAussie Posted June 11, 2018 Report Posted June 11, 2018 This is a method I use to help make my prototypes quickly and neatly. The example product is a double zippered key purse which unfortunately had a design change halfway through. The first 3 pictures show the key purse when finished. This one is the side that holds the most bulky key bunch. This is the other side This one shows what it all looks like when closed up. The following picture shows the patterns I've drawn for this model and they are the patterns for first cutting the pieces. They are 2mm all around over the size they will be cut down to in later steps. This picture shows how before cutting out I give the thin cardboard a spray with some contact adhesive and left to dry for 1/2 hour or more. Brushing on is alright as well but do it light and quick so as to not change the cardboard shape. The patterns now hold down well for cutting out if placed onto a poly cutting surface. The poly cutting boards for kitchens work well as well. Here I show the 1st cut patterns neatly cut and no movement. Next I use the same procedure for the second cut patterns shown below All the patterns cut out and shown below Next a sharp knife is used to cut out the leather pieces. Note that the glue holds down well still but not enough to damage the leather when removed. Shows cardboard being removed. All the leather parts needed are now cut out. The crocodile parts will come later. I think that is the limit of pictures I can load in one go so more a bit later. Quote
RockyAussie Posted June 11, 2018 Author Report Posted June 11, 2018 Ok now the leather bits cut above are all bits for lining on the crocodile and must be split down to about .5 mm so this next picture shows what we started with is about 1.4mm- After splitting .5mm A little bit more skived of around the edges Now the design change- The customer wants the prototype in black matte croc and this skin I though would be nice to use is a bit small so I wont be doing the folded edge on the zips. This is the skin- Cardboard attached to skin for cutting next All the croc now cut out shown The croc is a bit thick at 1.1mm A run through the splitter and is now .7mm. The 2 pieces on the left are the bottom splits. Next its time to start putting it together so I've decided to spray glue them all in this case. Here they are now with the linings all attached. More a little later Quote
garypl Posted June 11, 2018 Report Posted June 11, 2018 Great tutorial - looking forward to seeing more steps and thanks for taking the time to document your process. I know it takes extra effort to setup your camera during each step, take pictures, then resume your project - much appreciated! Gary Quote
RockyAussie Posted June 11, 2018 Author Report Posted June 11, 2018 On 6/11/2018 at 10:34 AM, garypl said: Great tutorial - looking forward to seeing more steps and thanks for taking the time to document your process. I know it takes extra effort to setup your camera during each step, take pictures, then resume your project - much appreciated! Gary Expand Thanks Gary, I will post more tomorrow as dinner is ready now and its hot Quote
RockyAussie Posted June 11, 2018 Author Report Posted June 11, 2018 The next step from here is to second cut all of the now attached pieces down to their finished sizes. Here the cardboard pattern is attached to the gusset piece- This one shows one of the top pieces ready to second cut. Below are all the pieces now second cut. As we are not now folding the croc edge along the zips we have to use some edging to improve the finished appearance. The 4 zip line edges now completed with 2 coats of edge coat each. Next with a prepared pattern the zips are glued and lined up in place - This picture shows the zips attached and ready to start the stitching- My trusty old Pfaff cylinder machine does a beautiful job. This is what we now have left to assemble- The middle lining is now glued to attach to one of the outer pieces- showing the piece now attached Here I start to stitch the gusset side pieces into place More to come later. Quote
Members noobleather Posted June 11, 2018 Members Report Posted June 11, 2018 (edited) Awesome tutorial Rocky Aussie. Make it look so easy but I guess that comes with a lot of experience. Inspiring stuff yo read for people just starting to deal with their leather addictions,keep em coming. PS I may have to buy some croc skin of you for some knife sheaths Edited June 11, 2018 by noobleather Quote
Contributing Member fredk Posted June 12, 2018 Contributing Member Report Posted June 12, 2018 A most excellent tute Quote
RockyAussie Posted June 12, 2018 Author Report Posted June 12, 2018 On 6/11/2018 at 11:30 PM, noobleather said: Awesome tutorial Rocky Aussie. Make it look so easy but I guess that comes with a lot of experience. Inspiring stuff yo read for people just starting to deal with their leather addictions,keep em coming. PS I may have to buy some croc skin of you for some knife sheaths Expand Thanks, I was hoping somebody might notice it. For the croc skin given your location I would give Valerie Douglas (in Broome) a call and tell her it was at my suggestion if you like. She is a very nice lady and I have a great respect for her. If she would prefer I could do it from here for her if you only want a small piece to try out. Here's a couple of pictures of croc knife pouches I've made from skins like she has. The last one, I had to get that knife as it was an anniversary one and shared my birth year. On 6/12/2018 at 1:04 AM, fredk said: A most excellent tute Thanks @fredk Expand Quote
RockyAussie Posted June 12, 2018 Author Report Posted June 12, 2018 (edited) This should be the last round now-- Both the gussets get stitched down Next is the other side stitched on Little straps for the key ring attached Now the final stitching gets completed. Note: they get carefully backstitched into the same holes- The case now gets turned inside out and pressed into shape That's it all and thanks for looking. Comments are welcome Brian Edited June 12, 2018 by RockyAussie Post doubled up Quote
Members RedDun Posted June 12, 2018 Members Report Posted June 12, 2018 Awesome instruction... Thanks! Quote
garypl Posted June 12, 2018 Report Posted June 12, 2018 Brian - that was a great tutorial and nice looking pouch you made. I bet one of the hardest parts of making it was turning it inside out at the end to make it look so even! I really do appreciate your efforts to help us learn new techniques. Gary Quote
Members bullmoosepaddles Posted June 12, 2018 Members Report Posted June 12, 2018 Great post. Thank you for all the work, help and comments you make for the purpose of helping educate your fellows. Go well Sir. Quote
Members noobleather Posted June 12, 2018 Members Report Posted June 12, 2018 Thanks again Rocky Aussie.top advise Quote
Contributing Member fredk Posted June 12, 2018 Contributing Member Report Posted June 12, 2018 On 6/12/2018 at 10:33 AM, garypl said: ... I bet one of the hardest parts of making it was turning it inside out at the end to make it look so even! Expand I was thunking the the same thinks Thanks, a very informative tute Quote
Members jimi Posted June 12, 2018 Members Report Posted June 12, 2018 Thanks for sharing that rockie. so is it divided in the middle with the lining?? one side for keys and the other for dosh? Quote
RockyAussie Posted June 12, 2018 Author Report Posted June 12, 2018 On 6/12/2018 at 9:55 PM, jimi said: Thanks for sharing that rockie. so is it divided in the middle with the lining?? one side for keys and the other for dosh? Expand Hey jimi, yes that is correct. One side has the gussets and the other not. On 6/12/2018 at 10:33 AM, garypl said: I bet one of the hardest parts of making it was turning it inside out at the end to make it look so even! Expand Thanks @garypl turning inside out is not that hard but I should have pointed out that doing that with glazed crocodile would be very difficult with out getting wrinkles in the glaze. I should also point out that if doing this in most leathers the leather lining would not be necessary. Thickness wise between 1 to 1.4mm (about 3oz) would work fine. Thank you all for the kind comments..... It helps to know if it is of any help to anyone Quote
Members MG513 Posted February 14, 2021 Members Report Posted February 14, 2021 On 6/12/2018 at 10:13 PM, RockyAussie said: Hey jimi, yes that is correct. One side has the gussets and the other not. Thanks @garypl turning inside out is not that hard but I should have pointed out that doing that with glazed crocodile would be very difficult with out getting wrinkles in the glaze. I should also point out that if doing this in most leathers the leather lining would not be necessary. Thickness wise between 1 to 1.4mm (about 3oz) would work fine. Thank you all for the kind comments..... It helps to know if it is of any help to anyone Expand I wouldn’t mind a vid on how you turn something like inside out frankly. I’m having a hard time wrapping my head around how you did it without ripping a stitch! Great work! Quote
