Anyone know what machine this Pro-2000 is based on?  It looks mostly like an Adler 205 to me, but the front-mounted tension is atypical.  Ferdinand built the Pro-1010 that looked almost exactly like this, but I haven’t seen this version of the Pro-2000.
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
I think it is based on the Juki 441.
kgg
Probably a Seiko frame.
Posted IMHO, by Wiz
Definitely not an Adler 205 or Juki TSC-441 design. Other current machines that appear nearly identical use a "GB6-180-2" model designation, sold under Thor and Kingmax brands. Top + Bottom feed machines. I've not found an "original" manufacturer that produced this design.
I'm starting to think that Ferdco just bought semi-random lots of machines, changed out a few parts, if any, and put their seemingly home-made Ferdco stickers on it. Many Ferdco models appear to be more of a marketing/branding exercise than an engineering effort. Not much different than the current crop of clone manufacturers or badge engineering resellers like Consew. Ferdco built their reputation with the early models that were modified genuine Juki TSC-441 machines. They soon moved to cheaper, anonymous clone manufacturers.
Here's a picture of the Thor GB6-180-2 just for comparison:
Uwe (pronounced "OOH-vuh" )
Links: Videos
Ferdinand Bull was built on a Seiko that was badged Consew but wore the Ferdinand brand.  Jump foot, needle feed and a good machine.  Also known as a 900B.  I have owned 2 of them.
Ken, it’s not a 900B.
Uwe, I had also found the Thor machine, which is clearly the same, as is the Cowboy 7205. I’ve also looked through Singer history and can’t find a match.  I’m beginning to suspect you’re right about Ferdo - at least in their later history.  What makes this interesting is the Super Bull labeling, as that’s late in Ferdinand/Ferdco’s branding, and they were still using 441 machines for the Super Bull Pro 2000 branding.
Keystone Sewing (keysew.com) has a short Ferdinand/Ferdco history that reads as though it came from Ferdco:
The Pro 2000 was designed by Ferdinand JeanBlanc in 1991 using a Juki 441 frame from Juki USA. In 1995 we went to a Tiawan manufacturer and had the 441 changed to our new specifications which we use now. Once the casting is delivered to us, we convert the 441 into the Super Bull Pro 2000 that you see advertised today.
You may be familiar with some of the other proceeding versions of the Bull or heavy stitchers Ferdinand has designed and built in the past.
These would be:
The Chandler 305 Bull - From 1964 to 1968
The Alder 105 Bull - From 1968 to 1979
The Adler 205 Bull - From 1980 to 1985
The Ferdinand 900 Bull - From 1985 to 1993
The Juki Pro 2000 - From 1993 to 1995
And the Ferdco Pro 2000 'Super Bull' - From 1995 to Present”
In any event, it’s a machine I think I’ll pass on, as parts and maintenance are always a concern.  That’s the beauty of the clone machine market, I guess ... keeps things alive.
I was eyeballing that machine too.  In the end I decided to pass on it as well before even going to take a look.  Too far away unless I knew the price was right but the ad only states to make an offer.  Since the pedigree of the machine is in question, I don't know what to ask for it except for my standard starting bid of 100 bucks.
The base Chinese machine is a GB6-182 which is a simple walking foot machine using the same shuttle as the Singer 7-5.
