Members shoepatcher Posted August 18, 2018 Members Report Posted August 18, 2018 Chrisash, The 29K series 29K51-56 of which your machine is one has very small teeth on the drive and following pinions as well as the drive rack underneath. These parts are critical because there are no replacement parts that I know of anywhere. I have some original pinion and a rack that are unused. The reason, to back engineer them to have them made which is a future project. The extra small teeth on the gears and racks raise the risk of wear and possibility of chipping so treat the ones you have on your machine with extra care. Just my two cents! glenn Quote
Members chrisash Posted August 18, 2018 Author Members Report Posted August 18, 2018 Many thanks for the information, can you supply the numbers of the bits you mention so i can look this side of the pond Quote Mi omputer is ot ood at speeling , it's not me
Members Constabulary Posted August 18, 2018 Members Report Posted August 18, 2018 (edited) Parts list for your machine: SINGER 29K51,29k56.pdf Edited August 18, 2018 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted August 18, 2018 Members Report Posted August 18, 2018 Chrisash, The 29K series 29K51-56 of which your machine is one has very small teeth on the drive and following pinions as well as the drive rack underneath. These parts are critical because there are no replacement parts that I know of anywhere. I have some original pinion and a rack that are unused. The reason, to back engineer them to have them made which is a future project. The extra small teeth on the gears and racks raise the risk of wear and possibility of chipping so treat the ones you have on your machine with extra care. Just my two cents! glenn Constabulary, thanks for the parts list. glenn Thanks for the Quote
Members chrisash Posted August 19, 2018 Author Members Report Posted August 19, 2018 Shoepatcher When you get them made, please put me down for a set, fantastic you have a virgin set , so copies will be made from original measurements rather than half worn out ones Guess you mean parts, 82067, 82104, 82069, 82108, 82106, 82071. Failing that can you convert to any of the other versions if it breaks chris@cjashdown.co.uk Quote Mi omputer is ot ood at speeling , it's not me
Members chrisash Posted August 19, 2018 Author Members Report Posted August 19, 2018 Shoepatcher Just been looking up 3D printing of metal objects and it looks like they can make up the parts required in either Stainless steel or normal steel which may well be the quickest and cheapest way to go with a few made at the same time I would guess your parts could be scanned into a cad package to produce the data required Quote Mi omputer is ot ood at speeling , it's not me
Moderator Wizcrafts Posted August 19, 2018 Moderator Report Posted August 19, 2018 The time and materials cost will probably exceed that of having them milled and finished at a machine shop. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Drummer Posted March 24, 2025 Members Report Posted March 24, 2025 Someone I know has a singer 29K 72. The wheel does not turn easy looks dirty. Will need a hole going through and they have a singer29K 51 the wheel on that one turns easy look dirty no need serviced. I'd like to know what a reasonable offer would be for both of them a package deal to buy from them. Quote
Members Drummer Posted March 24, 2025 Members Report Posted March 24, 2025 I meant they both will need serviced. Sorry about the tables. I'm guessing they will need service. Mainly wondering what I should offer for both both of them give them a fair price for what they are in the condition they're in. Quote
