Members Crispin Posted August 19, 2018 Members Report Posted August 19, 2018 Made a Gorget yesterday. I laminated a piece of Kydex inside each piece to add strength and rigidity. Its strong light and I put an Antique finish for a nice look. Quote
Members DV8DUG Posted August 31, 2018 Members Report Posted August 31, 2018 Is the toaster oven for Pop-Tarts? Quote
Members battlemunky Posted August 31, 2018 Members Report Posted August 31, 2018 Clearly that is not a toaster over, it is a Kydex warmer. Highly scientific piece of equipment! Quote
Members Sceaden Posted September 8, 2018 Members Report Posted September 8, 2018 Very nice! I like the idea of kydex as the core of your leather armor, strong and rigid without adding much weight. Quote
Members kiwican Posted September 8, 2018 Members Report Posted September 8, 2018 And you just straight up drilled through the leather and kydex for the copper rivets? Quote
Members DJole Posted September 8, 2018 Members Report Posted September 8, 2018 45 minutes ago, kiwican said: And you just straight up drilled through the leather and kydex for the copper rivets? I bet that's what he did. I've some armor bits where I punched the holes in the leather first, then marked the holes in the Kydex, and drilled the holes through the Kydex. Quote
Members Crispin Posted September 19, 2018 Author Members Report Posted September 19, 2018 On 9/8/2018 at 6:30 PM, kiwican said: And you just straight up drilled through the leather and kydex for the copper rivets? Actually this kydex .093 I was able to just use a standard hole punch, but I have also drilled it. I can also use the Cobra class 4 and stitch through the leather and kydex. Quote
