Members FloridaLeatherGirl Posted October 26, 2018 Members Report Posted October 26, 2018 I have sern folks say sanding/buffing creates the proper nap for rough out but darn if I can find an explaination or technique video illustrating this. Rough out for saddles is less fuzzy than what its line from the store. I have 2/3 of the Stohlman saddle making books and that dang one I DO NOT have happens to be the one that talks about how to do rough out. And ya cant find JUST that third book for sale >:( Quote
Members Clintock Posted October 26, 2018 Members Report Posted October 26, 2018 Tandy has a book. Well it’s sll the stohlman books combined. It runs around 170 bucks. Might be worth looking into. As for making rough out less fuzzy, I have no idea. Quote
Members robs456 Posted October 26, 2018 Members Report Posted October 26, 2018 16 hours ago, FloridaLeatherGirl said: sanding/buffing creates the proper nap for rough out Yes. 16 hours ago, FloridaLeatherGirl said: darn if I can find an explaination or technique video illustrating this. It's sanding. Start low grit, go to as high grit as you need. 16 hours ago, FloridaLeatherGirl said: Rough out for saddles is less fuzzy than what its line from the store. Yes, and if it is too fuzzy from the store, get better leather. Sorry for the few words, but you seem to have the idea down already. Quote Instagram: rob5leather
Northmount Posted October 27, 2018 Report Posted October 27, 2018 On 10/25/2018 at 11:59 PM, FloridaLeatherGirl said: I have seen folks say sanding/buffing creates the proper nap for rough out but darn if I can find an explanation or technique video illustrating this. Rough out for saddles is less fuzzy than what its line from the store. I have 2/3 of the Stohlman saddle making books and that dang one I DO NOT have happens to be the one that talks about how to do rough out. And ya cant find JUST that third book for sale >:( A few comments from book 3, pages 466-467 and 534-535 Use a tight grained leather, firm uniform tight-fibered surface A cabinet scraper can be used to take off the looser fibers, down to the firmer leather, use plenty of force, work in all directions Sand the leather in a circular motion, use coarse emery cloth wrapped around a block of wood. Sandpaper deteriorates too fast. Sand forcefully in a circular motion It is best to sand all saddle parts while they are flat rather than after assembly. Only parts that show need to be sanded. Oil, it may look like you are applying too much but it will lighten as it soaks in and evens out Wait 24 hours, sand again On curved surfaces, don't use a sanding block. May need some touch-up during and after assembly. Hope this helps you along with your project. I looked on www.abebooks.com for volume 3, and see they start at about $300 US and go up from there! Tom Quote
