I pretty sure the short answer to this is no but there should be a simple solution for you
Harward stores like Home Depot, etc. sell nylon nuts and bolts. You should be able to use a standard chicago screw and just purchase a nylon nut that slides over the screw post. Should be about the right thickness too. You may need to drill out the nut.
Hope that's clear.
In the future likely better to have posted this as a separate question. Things can get buried in these post easily.
Eric Fisher
Fisher Custom Leather
"A Retirement Project"
https://fishercustomleather.wordpress.com/
Thank you
  • 2 weeks later...
On ‎1‎/‎13‎/‎2019 at 1:23 PM, Sebasopg15 said:
Hello everyone, this may not be the proper post for this, but where can I purchase Chicago screws with nylon washers for a QuickDraw Buck sheath I’m making? Thanks in advance!
You might also try some of the bigger "got it all" companies like McMaster-Carr....
thanks!!
That is damn nice @c2369zulu. Love those TKC scales too..beats the hell out of those grivory ones from the factory.
Edited by battlemunky
