Members Canadianrunner Posted November 4, 2018 Members Report Posted November 4, 2018 I'm making a book cover and am trying to glue some fabric to the inside of the cover. I used my normal cement and it just bled through the fabric as I was afraid might happen. This caused discoloring and doesn't look professional. Have any of you found an acceptable way to glue leather and fabric together? I know I can sew the fabric around the edges but that wouldn't allow the fabric to remain stuck to the leather as the cover moves. Thanks! Quote
Contributing Member LatigoAmigo Posted November 4, 2018 Contributing Member Report Posted November 4, 2018 (edited) I have successfully used HeatnBond UltraHold Iron-On Adhesive (ordered from Amazon) to glue fabric to leather. You iron the fabric onto the back of the leather. There will be no bleed-through. Edited November 4, 2018 by LatigoAmigo Quote
Rockoboy Posted November 4, 2018 Report Posted November 4, 2018 I tried this exact same thing yesterday. For my test pieces, I used a section of cotton drill and a section of poplin, which is (apparently) a lighter cotton type of cloth. These were adhered to a piece of 4.5mm vegtan. I tried a section of contact adhesive and a section of Titebond lll PVA, with a piece of flat acrylic and heavy weight on top of the test pieces. The contact bleed through the lighter 'colour and weight' material, and was a definite fail. The Titebond lll PVA did not bleed through. The heavier cotton drill, which was a darker camo pattern, did not bleed through at all. Interestingly, neither adhesive appeared to affect the flexibility of the leather, but I did notice where I had applied the Titebond lll past where the cloth covered, the dried Titebond lll cracked when the leather was flexed. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members chrisash Posted November 4, 2018 Members Report Posted November 4, 2018 (edited) I used Carpet spray, the tin is used by carpet fitters to stick carpet or underlay to the floor, did not seep through using polyester/cotton mix onto veg tan Only needed to spray the veg tan side with yellow tape over edges not requiring to be stuck Edited November 4, 2018 by chrisash Quote Mi omputer is ot ood at speeling , it's not me
Members KingsCountyLeather Posted November 4, 2018 Members Report Posted November 4, 2018 5 hours ago, Canadianrunner said: I'm making a book cover and am trying to glue some fabric to the inside of the cover. I used my normal cement and it just bled through the fabric as I was afraid might happen. This caused discoloring and doesn't look professional. Have any of you found an acceptable way to glue leather and fabric together? I know I can sew the fabric around the edges but that wouldn't allow the fabric to remain stuck to the leather as the cover moves. Thanks! Carpet spray will work but there is a contact spray version too you might like better. When using spray adhesive you should hold the can away from your work about 8” to end up with a cobweb type of finish on both pieces that way you will not have any bleed through. With contact spray, let both pieces dry to touch and press together like normal contact. I use large amounts of spray adhesive in my day job. It works very well. Quote
Members Canadianrunner Posted November 5, 2018 Author Members Report Posted November 5, 2018 On 11/4/2018 at 2:18 AM, KingsCountyLeather said: Carpet spray will work but there is a contact spray version too you might like better. When using spray adhesive you should hold the can away from your work about 8” to end up with a cobweb type of finish on both pieces that way you will not have any bleed through. With contact spray, let both pieces dry to touch and press together like normal contact. I use large amounts of spray adhesive in my day job. It works very well. Thanks so much. I've started looking at some. Is there a brand that you. prefer over the other? Quote
Members Husky3 Posted December 1, 2018 Members Report Posted December 1, 2018 I am using 2 different types of leathers, bison - which stretches, and another type (trade secret....) that is very thin about 1.5 oz. I am trying to use one on each side for parts of the design. I have found that using adhesive makes the thin leather dimple especially where it folds. My idea was to use an interfacing between then two. So would I just be using interacing (probably heat n bond) instead of any type of adhesive? I will be hand sewing and using fenice edge paint as well. This is for wallets and other small items. Other parts of the design I will use adhesive. Quote
