Members R8R Posted November 8, 2018 Members Report Posted November 8, 2018 4 hours ago, Leathermaker831 said: This is exactly the information I needed thanks to all of you. I really want to learn how to use the machine and get familiar with it how it is now with a clutch motor that it has. Do you guys think its going to be incredibly fast. Yes, and no. Depends on the condition of the motor and your ability to feather the treadle. Some people swear by them. I hated every clutch motor I ever owned. Quote
Members dikman Posted November 8, 2018 Members Report Posted November 8, 2018 5 hours ago, Leathermaker831 said: Do you guys think its going to be incredibly fast. In a word - yes! It requires a bit of skill, and lots of practice, to learn to control one to get consistent low speed sewing. It didn't take me long to change to a servo! Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Leathermaker831 Posted November 9, 2018 Author Members Report Posted November 9, 2018 What do you guys think this sewing machine is worth once I dial it in Quote
Members shoepatcher Posted November 9, 2018 Members Report Posted November 9, 2018 Thanks Bob. You know more about this machine than I do and I had a 144 short arm years ago and now own an Adler 220-50-73. Sorry. glenn Quote
Members PonTiki Posted December 8, 2019 Members Report Posted December 8, 2019 On 11/8/2018 at 3:15 AM, Leathermaker831 said: I bought this machine with intentions of sewing door panels. The gentlemen that took me in as an apprentice used to do his door panels with a long arm just like this one but his was a single needle. I remember he would say if only his machine was a double needle things would be easier. He would sew the vinyl and a layer of thin foam right through the cardboard and the look was amazing as well as the sun visors. The outcome would look factory, especially on older impalas like 1958-1964 that is all we worked on as far back as I can remember. Everybody would come to him that owned an Impala no other upholstery shop was able to accomplish his look and style. I came across this machine working order according to seller and at a resonable price. I did look for other options as well as new machines the long arm double needle in a Consew brand is about 6000 plus dollars Atlas levy has his brand for about 3000 and a little over. So I think I did good buying this machine. I did find a retailer that has a complete gauge set for this machine for 150 dollars here in California probably generic as well as another dealer that quoted me 800 dollars for a gauge set most likely Singer brand. The first dealer also let me know that the balance wheel on the front of the machine to turn it by hand is very expensive around 700 dollars. This handwheel was optional at that time. If I install a good servo motor and a speed reducer it will probably slow down the machine to where I dont need the balance wheel. The machine was just disassembled for transportation purposes it was mounted to its original table with most likely its original Singer cluth motor. I just hope this works out for me and that I am able to accomplish the style I am after. Overall I think I did good on this machine its a double needle and that itself will put me in a whole different level. No matter how good someone is you can always distinguish when a French seam was done in a single needle machine. Back to my original question does anybody know exactly what will be needed to change the gauge set, how many pieces are needed that way I know if the gauge set for 150 dollars would work and is complete. Thank you all for your help. Ralph How did you make out with changing needle gauges for your machine? Also you mentioned that you found a dealer in California that had sets for around $150. Can you let us know who that is? I need to get a couple different sets for my 145w as well. Thanks Quote
Members Happycow Posted July 18 Members Report Posted July 18 On 11/8/2018 at 2:27 PM, Constabulary said: 150 for a complete gauge set is a bargain even for generic parts. You need a feed bog, throat plate, outside presser foot, inside presser foot and the needle holder with attached needle bar when needle holder and needle bar is 1 piece. Sometime needle bar and needle holder are split parts and you just need the needle holder - depends on what you have installed. When you changed the parts you have to adjust the 2 hook saddles and drive gears and adjust the needle and hook timing. Is it helps - the 145w shares the gauge sets with the Seiko JW-28BL and probably other machines too. Not sure if the Adler 221 has the same gauge set s but I think so. Hope this picture from an old Singer catalogue helps: I bought a new gauge set for my Seiko LSW8BL. I can repair all my machines but, a bit intimidated by this project of changing a gauge to a wider one. Any video tutorial? Quote
