Members archeryrob Posted December 19, 2018 Members Report Posted December 19, 2018 I have the standard 1, 2, 4, 6 chisel punch set and it is barely as long as 3 pieces of 7 - 8 oz leather is. I have the sheath all cut and the welt glued in. I didn't want to just bang and dent in the side I am punching.Any suggestions on what to do or how to punch thicker stuff for stitching? Quote
Members archeryrob Posted December 19, 2018 Author Members Report Posted December 19, 2018 Could not add a second photo as they are too large. I am giving this to my daughter for Christmas and need to finish it. All I have to do it stitch the welt, punch the hole for the retainer and re-dye the edge where I sanded it. Quote
Members arz Posted December 19, 2018 Members Report Posted December 19, 2018 (edited) 3 layers of 8 oz is about 9mm? I believe that is about as long of teeth as you will find. My Wuta irons are about 9mm long I think. About 10mm is as long as they get. The KS Blade Punch irons might be a bit longer. You will have to use an awl to finish the holes or get a heavy duty sewing machine I am afraid. -Adam Edited December 19, 2018 by arz Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Members billybopp Posted December 19, 2018 Members Report Posted December 19, 2018 There are a couple of options that I can think of for using a stitching chisel in thicker projects. 1. Before gluing up all layers, punch through a couple of layers at a time, using already done layers as a guide for the ones below. 2. If it's already glued, use the hole already there as a guide and finish the holes with an awl. - Bill Quote
Members arz Posted December 19, 2018 Members Report Posted December 19, 2018 Nice sheath by the way! And beautiful knife Quote Machines in use: Ellegi (Atom GL12 ) skiving machine, Durkopp Adler 69-373 sewing machine Atelier Zander: Website Instagram
Members archeryrob Posted December 19, 2018 Author Members Report Posted December 19, 2018 (edited) Thanks, but I think I fixed my problem. Maybe what to do next time? I am not sure I can punch and line the holes up. I am a novice at this, this is the second sheath I have made and all the leather work I have done. I took the single punch to the grinder and made it longer. Man I get that 4 punch in and I can't get it back out. I guess they are not made for multiple sheets. How do you all do the welt end of a sheath? Edited December 19, 2018 by archeryrob Quote
Members machinehead Posted December 19, 2018 Members Report Posted December 19, 2018 31 minutes ago, archeryrob said: Man I get that 4 punch in and I can't get it back out. Try rubbing the punch across some beeswax. Quote
Members Josh Ashman Posted December 19, 2018 Members Report Posted December 19, 2018 When hand sewing I always use an awl. Quote
Members battlemunky Posted December 19, 2018 Members Report Posted December 19, 2018 I usually use the irons for perfect spacing and the awl to go through the many layers as well. Also, the irons get stuck because they aren't sharp/polished. There are some Youtube videos out there that show how to sharpen/polish them up and they'll glide through the leather. Quote
Contributing Member JLSleather Posted December 19, 2018 Contributing Member Report Posted December 19, 2018 No way I'd sit there trying to line up all the holes in multiple layers. Better to use your punch to mark the holes, then sew with an awl. You can still "prepunch" the holes - if you want - with the awl instead of with the punch. Something also been done... mark your holes, then punch with a sewing machine needle chucked in a drill press. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
