Does anyone know if there is a source for pink leather dye or white leather die that I can mix with currently available red dyes to make pink? Thanks all
You can order pink from Angelus.  You can also make pink by diluting red about 10:1 with denatured alcohol. 90% Isopropyl will work just as well. Play with the ratios until you get the shade thatyo like
Angelus makes a Lt. Rose colored dye which I have used. It's quite pink! (See their online color chart: https://angelusdirect.com/pages/color-chart)
You could also dilute it with their Neutral (colorless) dye if you desire.
I see Angelus leather paint, but I'm looking for a dye.
I think someone diluted Fiebeng's Oxblood and got a bright pink out of it...
YinTx
Using Angelus Light Rose I got the colors in the attached photos.
I diluted them with Angelus Neutral Leather Dye: https://angelusdirect.com/products/neutral-leather-dye
Light Rose Leather Dye: https://angelusdirect.com/collections/angelus-dye-1/products/light-rose-leather-dye
Light Rose is a hotter pink so used full strength gives a super brilliant hot pink color.
