Good afternoon!
As in the title - what is the difference between a Triple (Compound) Feed machine and a Standard Walking foot machine?  In looking for a machine I see some noted as "just" walking foot and some as compound/triple feed walking foot.
Thanks!
compound the foot walks , the dogs move on the plate. and the needle moves forward with the feet
Thanks thunder9 - so, on a standard walking foot the feet are all that does the "walking"?
The mechanism you are calling standard is dual, top and bottom feed, where only the feed dog and outer foot move together while the inside foot and needle remain static. This is not what leather sewers call standard. It is useful for sewing webbing, vinyl, cloth and upholstery leather. The earliest dual feed machines were made by Simanco from the 1920s, onward. I own a 1923 Singer 42-5 that has a spring loaded outside foot that moves back with the big feed dog on the bottom, then lifts and springs forward. Most of the modern era dual feed walking foot machines have teeth on the feet and a crank driven outside foot. The teeth on top can chew up and mark top grain veg-tan leather.
If you intend to sew veg-tan or bridle leather, do not get a dual feed walking foot machine. Get a triple/compound feed walking foot machine with smooth bottom feet. If you need a harness stitcher, get one that has a smooth feed dog, like the big Cowboy, Cobra and Techsew 441 clones. This feeder won't leave tooth marks on the bottom layer.
Posted IMHO, by Wiz
Thank you Wizcrafts! That explains it and helps narrow the choices down a bit!
Here is Wiz's video of a compound walking-foot machine that shows the movement of the "inside foot and needle."
https://www.youtube.com/watch?v=V-QjJgJKKVM
Thank you Tejas - and Wizcrafts!
  • 2 years later...
Hello! This is an old thread but wondering if you could answer what you think is best for what I make - I make slippers and end up sewing through quite a few layers: 2 of leather and then 2 of wool jersey and then a lining. It can be nearly 1cm thick by the time all the layers are together to join the sole. Can you advise whether it is best to get a true walking foot or if a top and bottom feed would be sufficient? I don’t use super hard leather, more like upholstery leather. Thank you.
To sew 1cm you will need a different kind of sewing machine than a standard upholstery class walking foot. It will have to sew thicker than those machines are built to sew. Most upholstery class machines max out at 3/8 inch, with is 10mm
There are a few options you have to sew this thickness. But, first you have to decide on the geometry of the arm. How will you be sewing the parts together: from the outside edge or inside the slipper? It would really help if you post some photos of the slippers or shoes you want to make. Otherwise, we are just going to guess wildly about the type of machine you will need.
Posted IMHO, by Wiz
Wizcrafts... I'm confused about your reply.  1cm IS 10cm.  Are you saying that most upholstery class machines, maxing out at 10mm would not be able to sew 1cm?
Edited by MtlBiker
Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
