Members KennethM Posted January 11, 2019 Author Members Report Posted January 11, 2019 On 1/9/2019 at 6:26 PM, Matt S said: Kenneth, are you using leather-specific needles? Ones designed for fabric have a rounded, non-sharp tip designed to part woven fibres whereas needles for leather have a cutting edge on the tip, which cuts through non-woven fibres and therefore reduces blowout on the back side. There's always a difference between the top and bottom side of a seam sewn with a closed-eye needle. Apparently needle-and-awl machines are better at this but they're not very common. I find that hammering or rubbing the seam flat helps with the appearance most of the time. Looks like you have a few issues with tension too, either that the top tension is too low, bobbin tension too high, or that your thread isn't feeding evenly (top or bobbin thread). As to the corner issue either your leather is shifting under the foot, or maybe your needle is deflecting (possibly due to shifting leather). Are you glueing or taping your leather before sewing? Because that can reduce layer slippage. It may be also that your foot pressure is a little high for that thickness of leather, so it's pushing the layers a bit to the side. Just from an aesthetic POV I'd reduce the stitch length a bit with that size thread. Helps with getting the stitches to line up with corners too. Oh and one final tip: practice on scraps not projects! Keep all your scraps, even a couple inches of sewing to check your settings can save you a lot of time and money. Hey Matt I am using leather spefic needles.But thank you. I am glueing my leather.Using E600..I was using leather cement from tandy but I wanted to try something different. I have the pressure feet as lose as possible when this was sewed.I suppose I should have practiced on a scrap for 3 layers.I did a practice run for 2 layers and it was perfect.Thank you for the tips On 1/9/2019 at 6:31 PM, kgg said: It maybe just the angle of the photos but to me it looks like your machines stitch length is not consistent even on the straight runs. I would first remove the top thread from the needle then take a piece of paper and do a straight run of 12 stitches with the motor, measure the distance between each hole and then do a straight run of 12 stitches by hand wheeling them through, once again measure the distance between each hole. All the holes whether they are made by using the motor or by hand should be the same. If the stitch length is a little iffy it may explain why the tension problem on the bottom. kgg I will try this out.I'm confident its fine tho! Quote
Members KennethM Posted January 11, 2019 Author Members Report Posted January 11, 2019 On 1/9/2019 at 6:47 PM, ljk said: This is a common issue on this forum. There is 3 issues # 1 tension, most machines release tension by knee lift and or by lifting lever. You have to sew with no tension release, and you may consider after stopping pull thread tight. I have adjusted my tension release at the very top of its travel. #2 I use SD1 needles seems to work with minimum eruption on the back side of the leather. #3 I use Merrow floss commonly used to put edge on patches. Available in small spools from red Rock Threads online. This thread is all poly, strong. and is fairly thick. It has good shine and shows well wallets and bags. You may not duplicate the saddle stitch but can get close. Thank you I will keep this in mind..not sure my needle point type.I just bought some new bigger needles. How do you turn corners with no tension realse 9 hours ago, Techsew Ron said: Hi Kenneth, I noticed on another forum you changed to a different type of presser foot that you purchased and mentioned you were having issues with it not coming 100% back down. This might be affecting your bottom tension as the tension is released when you raise the presser foot. Please send us an email to support@techsew.com and we'll follow up with some adjustments. Ron Thanks Ron.The pressure foot would stick before I switched them out,they still stick matter of fact but will give them a email. Quote
Members KennethM Posted January 11, 2019 Author Members Report Posted January 11, 2019 4 hours ago, jonl30 said: Not that this is the issue but I was told to make sure the needle is on the upstroke before raising the feet to turn so the hook could catch the thread and not miss the stitch Thanks man.I thought I was doing this but perhaps I did bring the needle up enough Quote
Members KennethM Posted January 11, 2019 Author Members Report Posted January 11, 2019 3 hours ago, brmax said: Yes, I agree also and you picked up a good tip in that. If your corners last stitch ends with the needle being down and after bottom center its going up. The amount can vary but try 1/4” or more to start. I feel the thread is then at a secure point to lift presser a bit to turn material. Is a smaller needle available or has this been considered. I understand each material has its go to size with threads. An 18&19 is my go to for 92 threads. Much of our time we will easily see a consistency when most of a products stitch line was sewn facing up. Its always a bit different looking when, we have to or just for convenience keep flipping over and stitching. Just something we try to pattern for even in our best stitch line. Good day to ya Floyd Ill have to keep this in mind and double check.I was using #69 with a 18 needle but just bought some bigger needles for #92 thread Can you explain what you mean when referring to consistency and sewn face up? Quote
Moderator Wizcrafts Posted January 11, 2019 Moderator Report Posted January 11, 2019 1 hour ago, KennethM said: Ill have to keep this in mind and double check.I was using #69 with a 18 needle but just bought some bigger needles for #92 thread Can you explain what you mean when referring to consistency and sewn face up? #18 needles are more likely to deflect and break than #19. I use #19 on machines with #92 (T90) thread (top and bottom). I know that a #18 needle produces a tighter hole and might resort to using one for a particular job where the knots could move with a #19. I would be very careful while sewing to avoid deflections. Breaking needles on industrial sewing machines can be like mini-IEDs. Sewing face up probably refers to sewing on the top grain, or outer side (e.g., wallet back), as opposed to sewing from the inside out (e.g., wallet interior side). The top side (needle entry) always looks nicer than the bottom (needle exit) on a typical sewing machine. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members KennethM Posted January 11, 2019 Author Members Report Posted January 11, 2019 7 hours ago, Wizcrafts said: #18 needles are more likely to deflect and break than #19. I use #19 on machines with #92 (T90) thread (top and bottom). I know that a #18 needle produces a tighter hole and might resort to using one for a particular job where the knots could move with a #19. I would be very careful while sewing to avoid deflections. Breaking needles on industrial sewing machines can be like mini-IEDs. Sewing face up probably refers to sewing on the top grain, or outer side (e.g., wallet back), as opposed to sewing from the inside out (e.g., wallet interior side). The top side (needle entry) always looks nicer than the bottom (needle exit) on a typical sewing machine. Ah that makes sense.Thank you Quote
Members KennethM Posted January 12, 2019 Author Members Report Posted January 12, 2019 Got a questions for everybody since I'm new and still learning about sewing machines. Shouldn't the needle and middle foot touch the material your sewing/feed dog together in sync?Becuase mine do not . Quote
Members KennethM Posted January 12, 2019 Author Members Report Posted January 12, 2019 I did a paper test.I used the hand wheel to check my stitching spacing and its off.I'm not getting correct stitch spacing. 1)why is the happening? 2)how do I fix this? Quote
kgg Posted January 13, 2019 Report Posted January 13, 2019 For the presser foot issue is this similar to the problem you had previous with this machine? Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members KennethM Posted January 13, 2019 Author Members Report Posted January 13, 2019 3 hours ago, kgg said: For the presser foot issue is this similar to the problem you had previous with this machine? Yes thought I fixed it..guess I didnt do it properly Quote
