I have a huge mare I believe needs a draft tree.
I have her tracings and pictures to sent to a saddlery but before they go can I get a measurement to help me look for saddles now?
I’m not sure where I need to measure across the tracing to get a correct idea of width.
Is there a recommendation like two inches vertically from the top?
I’m going to add the side picture of her if anyone has any suggestions.
I'm not your guy, but there's a lot of saddlemakers on here. They should be by shortly!
So much leather...so little time.
I would take the tracings and take them with you to look at saddles.  What would you measure?  There is really no reliable way to measure the width of a finished saddle, because there is no real reference point once the tree is covered up.  Even holding tracings up under a saddle, I find to be of limited value. It will eliminate the ones that are the furthest from fitting, but the best option is to try saddles on horses.
Your mare looks like she will be a challenge to fit.  It looks to me like you are going to need a saddle with a lot of rock to the bars, and I daresay it's going to be next to impossible to find a factory saddle to fit. Is she a draft cross, and of what age is she?
She’s a percheron/french saddle horse cross.  She’s around 15 years old from what we were told but could be a couple years older.
She was retired from show jumping, bred once and hasn’t really been ridden five years. I know the sway is a big factor but if we can’t find anything wide enough it won’t make much difference.
I’m planning to cut her tracings from card stock to compare to saddles today.
My 10 year old is looking to show her in 4-H.  We had to start with a custom 66” girth but managed to make do with my saddle for the time being.
(She’s not really 32 and shaggy like the first picture implies)
She is a very good looking mare under saddle.  I could see the Percheron influence in the first picture.
There are saddles out there that will be wide enough, but what I find with the drafts and crossbred horses is that the bar angles are wrong, even if the width works.  I have personally not seen any good quality "draft saddles", so cannot comment on whether they come closer to fitting that an extra wide saddle made for light horses.  So in short, the point I'm trying to make is that the bar angle and rock are going to be more important than the width.  If the angle is correct, the change in width lowers or raises the front of the saddle.
While your mare does have quite a bit of dip in her back, her topline may be able to be improved through muscle building exercise and training.  My personal recommendation is to find a knowledgeable saddle maker in your area and enlist his help in determining what will end up fitting.  Even though a custom, handmade saddle may be out of your budget, many makers will still help you find a correct fit in a used saddle.  It will save you time, money and many headaches in the end if you can do so.  I sincerely wish you the best of luck.  I started out with Percherons, have owned many, and still have a great fondness for the breed. Your beautiful mare deserves the best chance you can give her in order to be a successful partner with your daughter.
That makes sense. Thank you. I’m kind if in a weird area, we have lots of riders but few tack shops and I don’t know of a single saddle maker/fitter.  My English saddle has an adjustable and gets very wide but still sits too high in the front which is what got us thinking wider tree to help level it.
I would be willing to haul an hour to the tack store but it’s all used and changes frequently. I may explain to the owner and have her call when ever a good possibility comes in.  Some of the trouble is we want to find a show saddle. Trail would give us a lot more try on chances.
Does anyone know of a saddlery near SE Michigan/NW Ohio?
Closest leather guy I know is four hours but doesn’t really do tack that I’m aware of.
I’m sure Indiana would have someone too.
 Thank you again, your advice really is appreciated.
Your best bet would be to ask around in your area. Sooner or later someone will have a recommendation.  I hesitate to recommend anyone whose work I haven't seen, or that i haven't been impressed with just by looking at pictures.  I thought someone from that area might see your post and respond, but apparently not.  There are some parts of the country that are more sparsely populated by saddle makers than others.;)
Just a thought, you could try asking for a recommendation on social media.  I am getting a larger and larger percentage of my work that way.  Good luck.
Hi there,
Living in Western PA now, also having problems with tack and saddles.
have two TWH with short backs and high withers, bridging is a problem. I don't want to transport horses days to fit saddles. Have decided to find a tree maker that will try to work with me, and make my own or find a saddle maker.
I'll be following
Almost any good saddlemaker will work with a long distance customer to get a good fit.  It is a little more challenging than being able to see and fit the horse in person, but it is done all the time.  If a custom saddle is in the budget, feel free to PM me to visit and for more info.  Most of the tree companies will work off a set of tracings, but the guys handmaking trees often offer more options and provide a superior tree.  There are exceptions however, because I just paid close to $700 for a handmade tree that not only has absolutely the poorest workmanship I've ever seen it wasn't even what I ordered.  So it pays to do your homework.;)
Thanks Big Sioux,
Budget? what is that? Going to have to do a lot of this myself, the tree will be a problem. Sorry about that tree a lot of money for something inferior.
