Members jimi Posted March 7, 2019 Members Report Posted March 7, 2019 If you do not have a connection at the bottom of the arm for the light, then probably that pin you are talking about is for the wires of the lamp. on the Fortuna there is a din pin at the bottom of the arm for plugging in the lamp. The lamp is the same one that Matts has on his Fortuna splitter machine so i think yours would be similar, goosenecked. Quote
Members katit Posted March 7, 2019 Author Members Report Posted March 7, 2019 Actually you can kind of see this pin sticking on back. And there is a hole in front (red arroows) And no, this is not original paint. I strip layers now and I see this greenish paint under this pale grenn/yellow. Quote
Members katit Posted March 10, 2019 Author Members Report Posted March 10, 2019 (edited) Some progress. All parts to be painted already stripped/cleaned and mostly primed. I use rustoleum bare metal primer, I think it's got acid for etching and my experience with it great so far. All rusty parts is actually acid cleaned, next I will do final degrease/acid and nickel plating. Overall it's a progress. Worst/hardest part is over. Inside of a main body was a PITA to clean. Piecing back clean/new parts should be easy/fun. The only thing is that from a factory it was painted after partial assembly. I may need to do the same because assembly happens metal to metal. I am going to prime top parts of a skiver lightly to prevent rust and then do partial assembly. Final paint will be with Valspar paint mixed with hardener and sprayed. This color should be pretty good match. I used this paint before and it dries very hard, has good gloss and very hardy. I may need to do some bondo on top/front of machine. There was about 1/16-1/32 from a factory to make it smooth/flat. https://www.amazon.com/gp/product/B000LNV5UU/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 Edited March 10, 2019 by katit Quote
Members katit Posted March 14, 2019 Author Members Report Posted March 14, 2019 Nickel plating is a failure so far. I don't get even plating on parts. Corners/etc get plated and then it burns. And it's very slow. If someone got experience/knowledge please chime in. My current understanding is that I need to copper-plate first in order for nickel plating to "stick". Metal used for parts is not very friendly. Quote
Members DanishMan Posted March 14, 2019 Members Report Posted March 14, 2019 Hi Katit Could you please give me update, on which parts you need. Brgds DanishMan Quote
Members katit Posted March 14, 2019 Author Members Report Posted March 14, 2019 On 3/14/2019 at 2:52 PM, DanishMan said: Could you please give me update, on which parts you need. Expand I think I'm good now. I ordered 1 part I was missing.. Quote
Members katit Posted April 2, 2019 Author Members Report Posted April 2, 2019 Got all parts chrome plated locally. Much easier than doing it myself Wasn't that expensive either ($75) All primed, filled and ready to coat of paint and assembly. Getting there slowly. Waiting on parts but should be here soon. Quote
Members Matt S Posted April 3, 2019 Members Report Posted April 3, 2019 Those parts look great katit. Looking forward to seeing the finished article! What colour you intending to paint it? Quote
Members katit Posted April 3, 2019 Author Members Report Posted April 3, 2019 Well. Thats a problem/dilemma right now. I really like to work with tractor paint from Valspar, it works for me (I'm not painter) and affordable. Makes very nice finish when used with hardener. So I picked this "Ford grey" as on a label it looks very similar to original paint. See bottom of can. Sprayed small parts and internals yesterday and it came out very close to white, just a shade of gray. Nothing like on a label. I have another can with black paint remains and I'm thinking about mixing little black into this paint to make it slightly darker. Or just paint like this? Will look like Consew Quote
Members katit Posted April 3, 2019 Author Members Report Posted April 3, 2019 Really bad news My iphone screen became unresponsive and they (Apple) had to give me a new phone. I couldn't even do backup (and they can't assist). Got new phone, which is nice, but all detailed pictures I took during disassembly now gone. I have couple pictures here and there but mostly will need to work off memory during assembly Quote
Members GRod Posted April 4, 2019 Members Report Posted April 4, 2019 Fear not. I had a similar thing happen to me when I replaced the timing belt on my wife's Audi a couple years ago. That job required taking apart LOTS of stuff just to get to where the work needed to happen. Not only did I get it back together, I had no parts left over (bonus!) and the car started & ran perfectly with the first turn of the key. Give yourself some credit. After all this time & work, you know the internals of that machine intimately; even if you don't realize it. You'll get it back together without a problem. Quote Greg "And you're a chip off the old block - why does it come as such a shock - that every road up which you rock your dad already did?" - John Hiatt
Members katit Posted April 4, 2019 Author Members Report Posted April 4, 2019 Yeah, I'm sure I will figure it out, all parts are different so it shouldn't be a big deal. Plus I posted many pictures in this topic which will be helpful. There is a lot of adjustments in machine and I was hoping to set everything in a rough "ballpark" using pictures, no way to do it anymore. Plus there is adjusting washers in skiving knife shaft which go to the certain side and now I will not remember it. Quote
Members lintonleather Posted April 12, 2019 Members Report Posted April 12, 2019 Wow I thought replacing a few parts on my Fortuna was going to be hard! You are on a mission well done! Btw anyone know where you can buy a 34mm wheel from? Quote
Members ElConquistador Posted September 3, 2019 Members Report Posted September 3, 2019 I have similar machine , by any chance does anyone knows the belt size for the pulleys,? Quote
Members katit Posted September 16, 2019 Author Members Report Posted September 16, 2019 Definitely not in rush completing this one. But new project requiring skiving came up and I'm back on a track. Will be even harder to remember what goes where but so far moving along. Did pre-assmebly of major components, bolted all that supposed to be painted together - together. Replacing all bearings, packing all with synthetic grease. Wait for paint to cure, scuff and do 2nd coat. I picked this darker color, not similar to original but I like it, looks nice in person. Quote
Members DanishMan Posted September 17, 2019 Members Report Posted September 17, 2019 Hi Katit Great to look your project to move ahead. I am about to take an old skiving machine apart and repaint it. Last year I tried to remove the main shaft of another machine, and it ended in disaster. You mentioned earlier in this thread, that it was tricky to remove the main shaft. What was the tricky part for you? Cheers DanishMan Quote
Members katit Posted October 4, 2019 Author Members Report Posted October 4, 2019 On 9/17/2019 at 7:22 AM, DanishMan said: Hi Katit Great to look your project to move ahead. I am about to take an old skiving machine apart and repaint it. Last year I tried to remove the main shaft of another machine, and it ended in disaster. You mentioned earlier in this thread, that it was tricky to remove the main shaft. What was the tricky part for you? Cheers DanishMan Expand Sorry, just noticed your reply. My post on page 1 from March 3 shows broken part (I had to order new one). This "fork" looking piece I thought it's pressed in but it's actually threaded. I tried to press it out and broke it. Other than that - there is no problem to remove it. Unscrew cap, then unscrew this "fork". I think one of them is left-hand threads Quote
Members DanishMan Posted January 13, 2020 Members Report Posted January 13, 2020 Good job. I have two old skivers, that I will start working on soon. Could you please tell me, how you removed the knife shaft with all the parts (worm wheel etc) Brgds DanishMan Quote
Members katit Posted September 4, 2020 Author Members Report Posted September 4, 2020 Never finished a project, now 2 skivers for sale here. Didn't list in anywhere else, leatherworker members get a first dib. Quote
