Members Mocivnik Posted March 21, 2019 Author Members Report Posted March 21, 2019 @Constabulary: Well, actually..quite common here. Dies comes from Italy and I don't really know why they use this system. Company called MOVI, from this site http://www.fbg-italy.com/ . The press was bought in Slovenia, but I believe it comes from Italy aswell, as I could find it in their catalogue. I don't mind very much about it, since I had bigger press and had to re-do taps on my dies (some time ago) so they were compatible as much as 1/4-24 as with M6 (the difference is really small, 1.4mm on 1 inch). I will buy tap and dye and just make all of them on same size (1/4-24) and hope never to change any system (as it's going to be VERY expensive). Quote
Members Matt S Posted March 21, 2019 Members Report Posted March 21, 2019 I have one press with a 1/4-24 top thread and one with a M8 top thread. It is a pain to have to keep track of incompatible top tools. Luckily the bottom tools are interchangeable. One day I'll get around to buying a kick-press and sell off my hand presses and all my incompatible dies. Quote
Members Mocivnik Posted March 22, 2019 Author Members Report Posted March 22, 2019 (edited) if I can help out here, buy a press like this. This is mine, I got used for 100€ or 86 GBP or 113$. I added the laser-cut measure guide with caliper-like scale (i draw it fast and just cut it out) so I can use different tools and just read out the number, how high has to be lifted the front part. The piston has hole in middle of 12mm or 12.7mm ( I don't remember) and I just turned the adapter for M6 inner thread (for my dies). Adapter could be seen just the tip. On the bottom, there is silver plate, which has hole of 12mm through, as all my dies have diameter of 11.9mm or 12.0mm. I planned to do just the "tip of the 24mm hole" for some other dies, but some things happened recently so I just abandoned further work in this workshop and moved to another. The press work through eccentrical mechanism and more you press it (down) easier it gets, the force gets bigger (but the movement is getting smaller). It's a bit complicated to explain, but this works like a charm. I still own it (this is from my ex. workbench) but due to some difficulties I'm facing, I can't reach it. (lifehack: sacrifice a wrench for a tool - like I did. I bought an extra one just for this press, driller 2 holes through it and attached 2 strong magnets. Everytime I need it, I know where I can find it. And I use it just for this press and nothing else. Both sides.) Edited March 22, 2019 by Mocivnik Quote
Members Kyle Mitchell Posted October 15, 2024 Members Report Posted October 15, 2024 Sorry for raising this old thread from the dead. I ended up with one of the Italian twist-type hand presses, as well. This topic was one of a very small handful of pages I could find online even addressing the threading for these tools. I bought my press from Campbell-Randall in Conroe, Texas. When I followed up with them, they provided some catalog pages for the Italian hand presses and accessories they distribute, which included a confirmation: Quote Upper tool holder threaded 1/4-24 with 12mm base. Campbell-Randall import a bunch of 1/4-24 tools to fit these presses, and also stock an adapter from 3/8" shaft to 1/4-24. Apart from the effectively proprietary threading, I really like the little No. 2 press. I'll probably end up with more Italian tooling sets, too, since I'm focused on footwear and Italy makes a ton of shoe hardware. But were I starting out from scratch, and especially if I weren't doing shoe work, I'd go with one of the more generic lever- or lever-cam-based hand presses with 3/8" collars and sets screws both top and bottom. Preferably one with a lot of spare tool height. Then get adapters and base plates for any tooling designed for differently threaded presses. Bizarrely, after digging through I don't know how many Italian shoe supply distributors' catalogs, as well as compiling a nice cheat sheet of Italian terms for "hand press" and "punch" and "die" and such, I still have no idea who actually makes these things. Just that they're in Italy. To Matt S's point, I have occasionally seen presses of this style, also offered as made in Italy, also in different shapes numbered 1 through 6, but with other threadings. So "Italian twist press" doesn't necessarily mean 1/4-24 madness. Based on spare parts listings for these presses in a few catalogs, the differences could be entirely in the driven shafts being threaded differently, with all other parts the same. If you're not in the EU, you've got an imported 1/4-24 press, and it's driving you insane, it might actually be cost effective to have a replacement shaft turned and tapped. Quote
Members Mocivnik Posted October 24, 2024 Author Members Report Posted October 24, 2024 @Kyle Mitchell not a problem for awakening the dead! Well, I've had same Italian press as you are, nr. 2, but thread on mine is1/4-24 correct, yes. You actually don't need this thread, unless you have some dies for other presses and need them to fit into this one, but since nr. 2 press has quite short piston movement, thread adaptors arent an option. I've had 10+ dies from all different presses, so I had to set them all on same thread on lathe to make them fit this press. Moving on, as with brand, who is making these presses, take a look here: https://www.fbg-italy.com/en/ Movi is one of my favourite companies, since they offer EVERYTHING and a small distributer delivers me weekly from their company directly. And concerning you and Matt S: Try using these kind of presses. They're not twist, but lever type with 10mm, 12mm or 1/2" and you can have adapters to change for any known and unknown thread there you want. Quote
Members Kyle Mitchell Posted October 24, 2024 Members Report Posted October 24, 2024 @Mocivnik, I followed up again with Campbell-Randall, who mentioned that SPS Technologia Meccanica of Vigevano, Pavia, Lombardy, Italy manufactures the numbered twist hand presses they distribute. I am pretty sure Movi, a brand of Fratelli Barbieri, is instead what we in shoemaking call a "finder"—a distributor of products from several manufacturers, rather than a manufacturer itself. Italy has many good finders, including TAN, CIAC, newer online sellers like Tutto per la Calzatura, and others. There are also many in Germany, who often focus especially on orthopedic shoemaking. You will sometimes see products with finders' brands marked on them. For example, I have a pair of lasting pliers marked TAN. But these are often white-labeled by the manufacturers for their larger finder-distributor customers. I've seen the very same pliers online with other brands marked on them. I agree that many leatherworkers would be well served with a cheap, generic arbor press like the bluish-purple one you pictured. I had one myself when I primarily made small goods and cases, before I started making shoes. The standard advice was to buy one from a budget Chinese tool store, like this one from Harbor Freight in the United States, then: Grind off a tooth at the bottom of the arbor so that it ratchets at full height, so you can reposition the angle of the handle when the arbor is fully depressed. Bore a hole in the face of the arbor, drill and tap for a set screw on the side of it, and epoxy a neodymium magnet to the bottom of the hole, so you can fix tools in place. Weaver Leather Supply let me know that they will be launching a new press later this year. Their plan is to ship it with adapters for many common tooling threads. That may become the best option overall for many makers. I'll be surprised if it's cheaper than the ugly little Chinese one-ton arbor presses, though. Quote
