Members chrisash Posted April 6, 2019 Members Report Posted April 6, 2019 After watching others making Mallet heads I thought I would give it a try making a tapered head using 3D Printing I used Nylon for the head "Taulman 3D 230" filament with width 50mm length 50 mm and hole in centre at 10mm dia IF you chose to make it then you need to change the bottom layer in Cura to Cylinder so it lays the filament in rings around the design for strength rather than normal up and down accross the design also 100 percent fill The beauty of this file is that in your slicing software you can change the height or width to whatever you need to make a small or large weight mallet Photoshows raw from printer without cleanup Nylon Mallet Head with taper.stl Quote Mi omputer is ot ood at speeling , it's not me
bikermutt07 Posted April 6, 2019 Report Posted April 6, 2019 Cool. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members dikman Posted April 7, 2019 Members Report Posted April 7, 2019 It remains to be seen whether a printed mallet head is able to stand up to the impacts of heavy hammering without delaminating, but it's a neat idea. Thanks for including the .stl file, it's always nice when people do that so others can have a play with it themselves. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
