Members JC2019 Posted May 13, 2019 Author Members Report Posted May 13, 2019 1 minute ago, Halitech said: https://www.tandyleather.ca/en/category/3-d-leather-stamps You can also have them printed on a 3D printer or some people make them on Delrin rods with CNC machines Nice thank you! Do you know if they sell these in "fonts"? So I can stamp letters Quote
Contributing Member fredk Posted May 13, 2019 Contributing Member Report Posted May 13, 2019 12 minutes ago, JC2019 said: Nice thank you! Do you know if they sell these in "fonts"? So I can stamp letters Yes, they sell sets of letter stamps. They range from about 3/8 inches high to about 1 inch high. They are mostly upper case letters [capitals] but sometimes they do matching lower case letters. The range and availability comes and goes. eg. I got a set of upper case letters from Tandy but the lower case had been long discontinued - I found a set in a US dealer's old stock heres an example; https://www.tandyleather.eu/en/product/craftool-standard-alphabet-sets Quote Al speling misteaks aer all mi own werk..
Members klutes Posted May 13, 2019 Members Report Posted May 13, 2019 51 minutes ago, JC2019 said: What did you buy and would you do the same today? What made you go all in so early? I knew from the get go I had no interest in hand sewing. Did all of that that I wanted years ago when I was in reenacting. Bought a CB3200 first. Now have a Adler 69 and a Adler 30-7. 54 minutes ago, JC2019 said: What did you buy and would you do the same today? What made you go all in so early? I knew from the get go I had no interest in hand sewing. Did all of that that I wanted years ago when I was in reenacting. Bought a CB3200 first. Now have a Adler 69 and a Adler 30-7. Quote Machines: Adler 69 , Adler 30-7, Adler 467, Cowboy bell skiver, Beilers embossing machine
Members JC2019 Posted May 13, 2019 Author Members Report Posted May 13, 2019 3 hours ago, klutes said: I knew from the get go I had no interest in hand sewing. Did all of that that I wanted years ago when I was in reenacting. Bought a CB3200 first. Now have a Adler 69 and a Adler 30-7. I knew from the get go I had no interest in hand sewing. Did all of that that I wanted years ago when I was in reenacting. Bought a CB3200 first. Now have a Adler 69 and a Adler 30-7. What get you get a press and which kind did you get. Still researching those, I think I will start small and simple Quote
Members klutes Posted May 13, 2019 Members Report Posted May 13, 2019 8 hours ago, JC2019 said: What get you get a press and which kind did you get. Still researching those, I think I will start small and simple I have a one ton press that I use to punch holes in my belts. I use wood spacers for each size belt to ensure the holes are centered. I have three old Stimpson rivet,snap presses that I picked up off of eBay. Solid cast iron wonderful press. I have each set up for a particular rivet or snap task. I made or modified the tooling for each. I also have a old 5-10 ton not sure which arbor press that I may set up for small cricket press. Quote Machines: Adler 69 , Adler 30-7, Adler 467, Cowboy bell skiver, Beilers embossing machine
Members klutes Posted May 13, 2019 Members Report Posted May 13, 2019 (edited) Edited May 13, 2019 by klutes Quote Machines: Adler 69 , Adler 30-7, Adler 467, Cowboy bell skiver, Beilers embossing machine
Members AA3JW Posted May 13, 2019 Members Report Posted May 13, 2019 I ended up buying the one that Harbor Freight sells. It works ok for stamping, but not really for die cutting. I found a good deal on a techSew on Craig's list. It looks much the the Co;t in the above picture. It sews really well up to 1/2 inch leather. Quote
