Members tofu Posted May 22, 2019 Author Members Report Posted May 22, 2019 Thanks 26 minutes ago, JJN said: It is called a Face Plate. Quote
Members photo2u Posted September 11, 2022 Members Report Posted September 11, 2022 On 5/22/2019 at 11:23 AM, tofu said: Wow that's exactly the info I was looking for. Would not have considered "bronze" would match grey. Thanks! What exactly is the front cover called? I can't seem to locate it. That is incredible how a name will be so misleading. I am going to give it a try. Will keep you posted. Now I got to learn how to blend/feather the paint to the rest of the body. Quote
Members EMI Posted September 11, 2022 Members Report Posted September 11, 2022 You may buy a couple of different colors ( e.g a silver & a darker grey) and mix them to get the right shade. You will need a spray gun to apply it. The difficult part is to match the original factory hammered effect. Each paint ends up with different hammered effect depending on the maker, application method, paint dillution etc. For local touch-ups I've had better results by applying it with a paint brush or sponge in a dabbing fashion. Its still hard to get a 100% match though In the attached photos example of repaint job on a 226R i am working on. You may notice the difference from the original in the close up of thread tension controller mounting hole. Quote
CowboyBob Posted September 11, 2022 Report Posted September 11, 2022 Re-assembly will be easier if you plug the screw holes with something to prevent the paint from going into them.We've use Q-tips,cotton , even pieces of paper & there are a few area that need to be masked off too.We also have a thick piece of paper business card thickness we used for covering the slide plate area.This hammertone will come out nice but be sure to wash the machine off a couple of x with alcohol to remove oil,if not you'll end up with a fisheyes.Also when painting wait maybe 10 min between each coat just so it's drying but still tacky & respray(hold can away from machine & mist it on) it will bring out the hammertone & don't forget to shake the can alot the oil in the can settles quickly.After your done & if your happy with it it needs some heat to bake the paint,we usually like to paint in the summer & let them set outside for the day in the sun,in the winter we'd put a heat lamp on them & tinfoil over the top to hold the heat in.This will harden the paint & prevent scratches when you put it together. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
