I used to own a 31-15 that was motorized, so I know the capabilities. Hopefully this is a stupid question, but here goes. I purchased a machine someone had taken home from a factory that used treddle machines, who knows when. It had a 2 extra aftermarket cast bobbin carrier holders. It was missing a nut on the bottom, and everything that could be tightened, was loose.  It had a home needle in it, and the drawer was full of vintage home needles. The bobbin hook was rounded and wouldn't catch the thread, so I ordered a new hook and carrier, and installed the correct needles. (Yes, I know which direction to put the needle in). The timing looks right with the exception of when I install the cast piece and the bobbin carrier group the machine seizes up. Loosen the retaining screws, and the machine functions fine, but the needle drags across the edge of the bobbin hook. Here's the question. Does anyone know the correct way to adjust the bar so it doesn't jam the bobbin hook into the iron carrier? I see a set screw where it can be rotated around, but I need it to be just a hair shorter, away from the bobbin carrier group.
Have you checked that the needle bar height is correct?  It may have been lowered to use the home machine needles.
Or maybe I'm misunderstanding the problem ......
The model number giveth, and the subclass taketh away ......... Sometimes
While you are putting things right, be aware that Singer did NOT use standard threads on their machines, so hardware store screws and nuts will not work.  They had their own proprietary threads on their hardware.  You will need to get screws, etc. from dealers in Singer parts, or have them custom made.
Wrong direction. The bobbin race unit is too far forwards. The needle height is fine.
Learned that the hard way. I now have a handy little thread pitch gauge and a direct line to the local Singer parts dude.
Not sure if you have seen this video,  this guys is very good explaining thing, good luck.
Yep, watched it. I didn't see him cover what I need. I need to adjust the shuttle driver/oscillating shaft inwards. The needle is rubbing the side of the hook by about 1/16 of an inch.  The adjustment of the needle/dogs is nicely explained, but that's not what I need.
It sounds to me like the new replacement casting is just a tad thinner than the old original race, or the new hook is just a tad thicker than the original hook.
Have you tried mounting the new hook with one or all of the old cast races?  If they also bind the machine up, I would think that the new hook is too thick.  If so, you might try making a shim of some sort to keep the casting set out just a little when tightened down.
CD in Oklahoma
"I sew, I sew, so it's off to work I go....."
My sewing machines:
Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Shimming the race out may solve the binding problem, but the hook may still hit the needle without some shimming behind the hook as well.
I’ve had a real problem trying to make the new replacement parts work on old machines, and in some cases, just had to throw them away and find usable parts from an old machine.
CD in Oklahoma
My sewing machines:
  • 3 weeks later...
figured it out. I had to shim the oscillating rod all the way to the right side of the machine to keep it from binding up the shuttle hook. Waiting on a new shuttle driver carrier hook (can't remember the name). Hopefully then all will be well.
