Hello,
I can't see how you would machine sew this type of seam (other than by hand) on both sides of the bag and wondering if I'm missing something?
Which seam ? There are multiple seams visible on that bag.
Edited by mikesc
"Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
To clarify I meant the main u shaped seam which is mirrored on the front and back of the bag.   It appears to be a simple lap seam.
Nothing hard about that with a machine..looks like a 1/8 th inch edge..either use edge guide on the machine ( swing down or mounted on the bed / arm ) or guide built into the foot..Go slow..Go carefully..The same method will also allow you to do the seam that is all around the top..Also the stitching on the straps.
Easier with a cylinder arm machine than with a flat bed..Possible with a flat bed , but you'll be fighting the leather and manipulating it a lot, with not a clear sight of what you are doing, and that may show in the final product as creases. Best not use a flat bed if you want to avoid throwing the bag and the machine out the window :)
Brian ( RockyAussie ) has posted a few videos and threads that show how to do very similar techniques..
edit : Thinking about it a little more, I think a "spring edge guide" on the foot would be easier than a guide on the machine.
Edited by mikesc
Maybe I’m missing something here.  So this bag is made essentially of three pieces the front the back and the one piece sides and bottom.   I can see how you could sew the front to the bottom sides.  Once that’s done though it seems impossible to repeat the operation sewing the back face on in the same manner.
You are right ....they can be tricky to impossible to do on a normal cylinder machine. If the pattern is big enough and the gussets can flare outward enough it is not too bad. If they are like the little one i make rarely (about 6 across) as in the picture below several steps are necessary. Firstly the gussets are only stiffened after the outer sections are sewn. On the second side it can sometimes be easier to start 1/4 way down the bag from the top in order to allow room for the cylinder arm to have room to go into the opening at the finish. It then can be easier to manoeuvre the bag to do the top down start. Notice in your picture that the bag has a separate lining and the stiff look to it can be deceptive, it is probably quite pliable. Some sewing machines like a patching machine would do it easily but they don't do a very nice job normally and some like this side wall stitching machine may be an easier way as well. There is a member  @robinindustry that has a variety of these machines for sale out of China.
On the second page in this earlier post you can see a video of a sidewall stitcher in action. Follow that back on the you tube and more can be seen as well.
YouTube Channel
Instagram
Thank you, very informative!   I hadn't really considered how pliable that leather might be before the lining is added.    Also those Robin Machines are rather interesting.
I've managed to do this style seam before with my patcher but as you mention the stitching quality/consistency really isn't there and I abandoned the idea.   I recently added a narrow 17" post bed to my shop, so maybe I should give that a shot too with a more pliable leather.
To confirm, you are sewing this black bag entirely on a cylinder bed?
Yes that is correct. Note where I said that the stiffener for the gusset area is put in after the stitching and I have to admit that i have to sort of walk the stitching around sideways a bit on 3 or 4 stitches as well. This is not to hard with my machine as it has a variostop motor where it enables me to lift the foot enough to step sideways and not loose my thread tension in the process. Make sure that your thread tension discs don't open when using your foot or knee lift. This is the machine I would have used in the making and it is a Pfaff 331 but a 335 walking foot type could do it as well.
YouTube Channel
Instagram
Very nice, also a good tip on the tension disc front, never thought of that.    Any pics of the gusset area stiffener you used?
I don't have any on hand but I will take a few shots of a prototype one I made and some further shots to explain better after I catch up on some of this work today.
YouTube Channel
Instagram
