Members Sharon Mallory Posted August 8, 2019 Members Report Posted August 8, 2019 Hi I’m having trouble with my nylon straps breaking on the backpacks I made. It seems like the strap just shreads from where it joins the main part of the backpack. I’m not using a leather needle on it. Does anyone have any suggestions on what to do, it’s not making me want to finish? Quote
Members Halitech Posted August 8, 2019 Members Report Posted August 8, 2019 Put a thin layer of leather over the nylon like some people do when making a guitar strap and they put a leather end on them. Quote Every day you learn something is a good day. If you don't learn something every day, was it worth waking up for?
Members TomG Posted August 8, 2019 Members Report Posted August 8, 2019 Some photos of what you are doing exactly would help Tom Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Sharon Mallory Posted August 8, 2019 Author Members Report Posted August 8, 2019 It’s just a simple backpack for my 9 year old grandson and it happened on the one from when he was 5 or 6 too. I want to make one for myself and figure out what the problem is and how to avoid it. Quote
Northmount Posted August 8, 2019 Report Posted August 8, 2019 I've had no trouble with these types of straps. Possibly your strap material is too thin, or poor quality. It looks like maybe the strap was nicked by a sharp item and started to unravel. I had straps on bags that were used to hold electronic vibration monitoring instruments and were used all day long in a dirty and challenging environment. No breakage of the plastic hardware or the straps. When the bag (fabric - canvas like exterior, padding, and a silky smooth lining) got dirty enough, I threw them in the washing machine to clean them up a little. So with all the abuse they suffered, I had no failures. Tom Quote
kgg Posted August 8, 2019 Report Posted August 8, 2019 Kids generally tend too be tough on stuff. When I have seen fraying that results in shedding like that either the nylon is being constantly rubbed / nicked against something, the nylon is less then good quality or to many stitches per inch in the stitch used to attach the material. I would suggest reducing your number of stitches per inch and or using a different type nylon that would be stiffer but more abrasive resistant. If the stitches are to close together the stitch will basically cut the fibres of the material. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Sharon Mallory Posted August 8, 2019 Author Members Report Posted August 8, 2019 I’ve used this same strapping before too but it didn’t hold up well last time and this time I had to replace the handle on top also as it had begun its fraying from the edges to. Last time I thought I forgot to change out my leather needle so I know for sure I did it this time. Maybe stitch length I’ll lengthen it. I’ve mad quite a few leashes and collars with this nylon before too. Going out of town so I thought I’d throw one of these together for myself and I don’t need it to break. This was the 2nd day he used it. Other than the straps which I replace years ago it held up well. This one I used sunbrella and I waxes the canvas. Quote
Members TomG Posted August 8, 2019 Members Report Posted August 8, 2019 2 things to try, if you haven't already. 1) Burn the ends of the nylon strap after you cut them. 2) Use a fairly long stitch.. 6-8 SPI or so. Make a couple of rows or better a square box with a "X" from corner to corner on. Tom Quote Tom Gregory Legacy Leathercraft www.legacyleathercraft.com www.etsy.com/shop/legacyleathercraft
Members Sharon Mallory Posted August 8, 2019 Author Members Report Posted August 8, 2019 Thank you, plus got better strapping Quote
kgg Posted August 8, 2019 Report Posted August 8, 2019 Since you are using sunbrella and canvas have to tried to make your own straps out of those materials? You have all the necessary strap connections and probably scrap / leftover material. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members nylonRigging Posted August 9, 2019 Members Report Posted August 9, 2019 (edited) 15 hours ago, Sharon Mallory said: It’s just a simple backpack for my 9 year old grandson and it happened on the one from when he was 5 or 6 too. I want to make one for myself and figure out what the problem is and how to avoid it. ( Looks Like ) .. when load bearing, Is your ( 1" ) Webbing breaking and shredding the weave on your toothed friction lock-bar on the Buckle ? . If so it's the type- webbing your using and you need to change to different . Where Getting, and what Webbing you using ? .. Nylon is strongest for friction and strength . Polyester is pretty strong and best for UV sun damage . and definitely If you using the cheap Polypropylene webbing, It will do this in the Pic. every time . edit add: Also under heavy load Bering, like a main lift of heavy packs and container systems . your webbing wrapped over any friction surface for best long life . It good to run a ' chaffing strip ' under the webbing wrapped over the hardware that load is hanging from. . . Edited August 9, 2019 by nylonRigging Quote
Members blue duck Posted August 9, 2019 Members Report Posted August 9, 2019 I might be over thinking this, but I don't use a leather needle when I work with this type of strapping. I thought it might be cutting the fibers. Quote May God Smile on you today.
