Fine looking holster, excellent craftsmanship.
I'm rebuilding a basket case early variation Single Six,and I'm considering getting a Bisley style grip frame. So far I've only got $20 in this revolver so I may decide to invest a bit or just finish it out as cheaply as possible.
Old methods I've used, mainly obsolete.
I use a stitching awl for holsters and most any thick pieces. I use the thick needle that came with it on thick areas but I use a somewhat more slender needle of a type used on upholstery sewing machines where ever possible because there's less drag that way.
To stitch very thick built up places I make the pre-punched holes deep enough using a Slender screw driver slimmed down a bit more with the head sharpened. When necessary I punch from either side so the holes meet.
While I've seen it recommended to cut a groove along the path of the stitching I prefer to use a narrow paint scraper with blade ground dull and polished to impress a groove. I've also used a small diameter pizza cutter similarly dulled to roll in a groove. For turning curves I use a screwdriver blade to impress between each punched hole. That way I don't have to break the surface.
the lock stitch of the awl allows one to draw the thread down tight into the groove so it sits even with the surface.
  • 2 weeks later...
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
Thanks for the advise and information on some of your tooling
  • 8 months later...
that's a really nice holster, thanks for showing us!
