wizard of tragacanth Posted September 2, 2019 Report Posted September 2, 2019 12 minutes ago, battlemunky said: I think I may get a cheater bar for mine as well, the handle that comes with it is a bit short and with a longer lever arm you can likely get some more effort out of it...it IS HR though, so maybe overclocking it ain't the best idea. Yeah, on that 1-ton HF press, I had to set the bar so that it was horizontal when making contact with the stamp, so that I could put all of my weight on it. Mine is not bolted down (so that I can easily move it if necessary) so I have to press with my strong hand and steady the unit by placing my other hand on top of the unit. Then I just lay into it for 10 seconds or so. This is for a 1" stamp. I have one of the 6-ton presses but I never bother with that for the 1" stamp. Of course, you could just slip a 2' piece of pipe over the handle for more leverage, if needed. Quote Nick
Members chrisash Posted September 2, 2019 Members Report Posted September 2, 2019 I was brought a half ton arbor, and I then brought a 1 metre length of 25mm steel tube, that goes over the bar when needed to give far more pressure, just slip it over the existing bar, not sure what the mechanical advantage is but must be quite a lot Quote Mi omputer is ot ood at speeling , it's not me
Contributing Member JLSleather Posted September 2, 2019 Contributing Member Report Posted September 2, 2019 25% off at HF today only. Jus' sayin' .... Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members battlemunky Posted September 2, 2019 Members Report Posted September 2, 2019 I looked at the sale and thought really hard about it earlier when I got the email reminder. I have run out of room and really don't NEED more crap. Saving 25% on anything is super tempting. If my dog offered me a turd @25% off I'd think about it. I do have to drive past it in a few minutes..... So.Torn. Damned American consumerism. Quote
garypl Posted September 2, 2019 Report Posted September 2, 2019 1 hour ago, JLSleather said: 25% off at HF today only. Jus' sayin' .... Picked up the 6 ton press today for $60 with the 25% discount. Heading down to set it up now! Quote Cowboy 4500, Consew 206RB-4
garypl Posted September 3, 2019 Report Posted September 3, 2019 I should have bought one of these a long time ago - can’t believe how easy it punches through the leather with clicker dies! Also set up my nephew’s 10 year old with a starter set - he has been over a couple of times and always asks to go make something. They are moving to Florida next month, so I hope he likes it enough to keep working at it! Quote Cowboy 4500, Consew 206RB-4
Contributing Member JLSleather Posted September 3, 2019 Contributing Member Report Posted September 3, 2019 Told ya Don't take up much room in the place neither. I got the bigger press out the shed, but this is nice for the smaller stuff. Quiet operation too. Now it WOULD be nice, think I might pick up the little 1-ton thingie... just to have one that you got the "feel" of the press.. more for snaps n such. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
garypl Posted September 3, 2019 Report Posted September 3, 2019 Any idea what clicker die size limit this 6 ton press can handle? It pushes the small 2.5” die right through leather. What is the largest size clicker die you have used with yours? Don’t want to spend money buying dies too large to use with this press. Quote Cowboy 4500, Consew 206RB-4
Contributing Member JLSleather Posted September 3, 2019 Contributing Member Report Posted September 3, 2019 (edited) Well, I know YOU know, and I know, but for others who DON"T know...... Different types of "cutting". (blanking, piercing, shearing, etc) but as a simplified rule.... the force required depends on the perimeter of the cut and the thickness of the material and of course how sharp or dull the knife (because it affects the area of the cut...). SO then, I've used this for these palm sized dies in 8 oz leather... got a length of cut of about 16-17". Think single mag pouch. I would think that spreading the force out across the die is more a consideration than the force involved. If you have a plate to cover it, I wouldn't worry about being able to blank out holsters for many autos. Now, a skirted western "bucket" could be an issue,... but that wouldn't' fit in there anyway. Wallets 'n' such, maybe you hit one end, move it over, hit the other end. Edited September 3, 2019 by JLSleather pic Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Contributing Member JLSleather Posted September 3, 2019 Contributing Member Report Posted September 3, 2019 Oh, maybe should clarify.... that SAME die, with two belt slots added (for example) would be the SAME size, but perhaps 30% more pressure needed due to the increased CUTTING LENGTH. Two slots 1 1/2" long x 5/16" wide would add about 6" more cutting surface to a die the same "size",... so.. this is why I mention this in a question of "how big of a die...." Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
