CFM Frodo Posted September 7, 2019 CFM Report Posted September 7, 2019 I use 22lr as decoration buttons on a belt and wrist band. I use plexe glass to hold the bullet while cutting, and s a height/debth gauge [can be adjusted by adding strips of leather or what ever ] I made a set tool using a brass 5/16 brass acorn nut, just jamb nut it on a rod, insert rod in a drill and let a file do its job For safety concerns, use USED bullet cases, You can see my brass is NOT used, and the primer will go off if you hit it wrong, scared the cat and the dog my wife rolled her eyes....primer going off is just loud,nothing fling around. Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Rockoboy Posted September 7, 2019 Report Posted September 7, 2019 That is an excellent idea for a pattern on an item for a shooter! Unfortunately, here in Australia, we are not permitted to possess any cartridges (live or used), projectiles or associated items without having that calibre firearm on a valid firearms licence. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
kgg Posted September 7, 2019 Report Posted September 7, 2019 Like the idea. Maybe if you used a larger calibre spent casing like a 45-70 it could be used in the construction of a belt. Seating the bottom cutoff of the casing so the prong of the belt buckle would go through the primer hole rather than just the normal hole in the leather. 16 minutes ago, Rockoboy said: Unfortunately, here in Australia, we are not permitted to possess any cartridges (live or used), projectiles or associated items without having that calibre firearm on a valid firearms licence. What a shame. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
CFM Frodo Posted September 7, 2019 Author CFM Report Posted September 7, 2019 34 minutes ago, Rockoboy said: That is an excellent idea for a pattern on an item for a shooter! Unfortunately, here in Australia, we are not permitted to possess any cartridges (live or used), projectiles or associated items without having that calibre firearm on a valid firearms licence. Here is my belt with 30/30 and 22 cases Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Rockoboy Posted September 7, 2019 Report Posted September 7, 2019 Possibly a belt with that sort of 'jewellery' would not attract any undue attention from our local LEO's because they are obviously unusable. On the other hand, as I have no firearms licence, a handful of spent cartridges would probably see the end of my career in the security industry. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members noobleather Posted September 7, 2019 Members Report Posted September 7, 2019 Great ideas for recycling old cartridges. Quote
CFM Frodo Posted September 7, 2019 Author CFM Report Posted September 7, 2019 43 minutes ago, Rockoboy said: Possibly a belt with that sort of 'jewellery' would not attract any undue attention from our local LEO's because they are obviously unusable. On the other hand, as I have no firearms licence, a handful of spent cartridges would probably see the end of my career in the security industry. If the spent cartridge came into your possession ALREADY cut, then it is not a spent cartridge it is just scrap brass Or so i am thinking. Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members Oldtoolsniper Posted September 22, 2019 Members Report Posted September 22, 2019 I like the jig, I have cut quite a few brass casings with varied results, never figured out how to do it straight except on my lathe. The lathe works but is a pain to do in quantity. My jewelers saw will be getting a work out. As for flaring the backside, would a splash rivet setter work on the smaller calibers? Quote
CFM chuck123wapati Posted September 22, 2019 CFM Report Posted September 22, 2019 cool idea indeed a fellow could pick up hundreds at the range or here in Wyoming almost anywhere lol. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
