Members Maker77 Posted September 11, 2019 Members Report Posted September 11, 2019 I am just starting to use a filetuse and was using it on an already edge painted side. But I had hell of a time getting a strait line with the Creaser. I’m wondering if I should not bevel the corner edges first? That is beveling before the paint. Do you even bevel the corners if you edge paint? Quote
Members jimi Posted September 12, 2019 Members Report Posted September 12, 2019 Hi, I have not done a lot of edge painting but I would try painting your edge on a non beveled one, at least Giardini recommends this for their edge paint. I have a couple of bottles of their paint and tried both ways and find when i do paint the edge it is not beveled otherwise i am running around the bevel trying to find the line to stop!!! Quote
RockyAussie Posted September 12, 2019 Report Posted September 12, 2019 I do quite a lot of edge painting but the answer depends on the thickness and stiffness of the leather. Once you get much thicker than 2mm you often start to get a split line in the paint that either has to be sanded out or ironed in or a bit of both. A bevelled edge gives the advantage of keeping the paint thickness build up into the middle and therefore less of a split line. You can see one example of how I do bevelling on belts in this video - https://www.youtube.com/watch?v=zY5wWvQvd1k In this vid you can see one of the ways I apply the edge coating on these belts.https://www.youtube.com/watch?v=UiQIHqY5lwk And in this one I am doing a more by hand method - https://www.youtube.com/watch?v=cR5nUxrrjec Just a tip - do NOT make your edges too smooth before applying the edge paint or you will find out that it can be peeled off in one big long strip as well. A sanded finish is best. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
