Members dreamsicle23 Posted September 25, 2019 Members Report Posted September 25, 2019 Hi all. I tried Google for an answer but I think I'm not searching the right terms. This is the only place I know of where there's a group who regularly use industrial walking foot machines. I'm wondering if it's possible, and if so - how, to make the outer foot lift higher when it takes it's "step". I don't necessarily want to reduce the pressure, and I don't want it to be higher when it's in the down position, but right now it gets hung up if I go over a thick seam and I get a wonky couple stitches. My machine is a 111 clone, if that matters. Thanks in advance! Quote
Members Constabulary Posted September 25, 2019 Members Report Posted September 25, 2019 and what clone is it? Please post some pictures. Hung on the raised material I guess , right? Usually there is a cam on the backside where you can adjust the foot height. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
mikesc Posted September 25, 2019 Report Posted September 25, 2019 This thread from 2017 "here" might be useful to you. Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members dreamsicle23 Posted September 25, 2019 Author Members Report Posted September 25, 2019 1 hour ago, mikesc said: This thread from 2017 "here" might be useful to you. It looks like this is exactly what I need. Thank you! Quote
Members Gregg From Keystone Sewing Posted September 25, 2019 Members Report Posted September 25, 2019 See attached, this is what you are asking about. Singer 111W155 uses a worm gear. Timing the preser lifting eccentric.pdf Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Tejas Posted September 25, 2019 Members Report Posted September 25, 2019 Attached below is a copy of that entire document. 111W155_Repair_NAVEDTRA_14217_01032011.pdf Quote
Members Constabulary Posted September 26, 2019 Members Report Posted September 26, 2019 (edited) I´m not 100% sure but do the 111 clones have the singer type "Foot Lift Eccentric" on the top shaft as well? AFAIK the clones have the slide cam (right word?) just as the Pfaff 145 / Adler 67. Or am I on the wrong track? Like this? EDIT: The manual came from Keystone Sewing: Juki_LU-563_Instruction_Keyfooter.pdf Edited September 26, 2019 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members shoepatcher Posted September 26, 2019 Members Report Posted September 26, 2019 C you are right. Should have the slide cam to make walking foot height easier. glenn Quote
