Solution found.  Hate to admit it, but I had a bottle here in the shop and forgot it.  :rolleyes2::lol:  Tested it on a piece and there is no rub off, no bleed!  Solution in hand!  Cheers!
  • Replies 42
  • Created
  • Last Reply
Top Posters In This Topic
  • 2 months later...
Ok, back on this topic.... sorry.  This is driving me mad!
I have on hand and have been experimenting with...Fiebings Edge Kote, Tokonole and Eco Flo Edge Flex (Fenice ?).  While I have yet to find a solution, the problem seems to lay with using wax.  Allow me to explain.
Fiebings:  Dyeing the edge, allowing to dry, there is little to no rub off of colour.  Once I use beeswax on the edge, the colour rubs off on a cloth and won't stop, no matter how long I wait.
Edge Flex:  I have found this to be utter expensive shite!   It just peels off like silicone.  Rubbish!
Tokonole:  I have only the clear (or white version).  I have deyed the edges and allowed time to dry.  Minimum of one full day.  No rub off of colour.  Once I apply wax to the edge, the colour rubs off.
I cannot for the life of me figure out what I am missing.  I thought it might have had to do with burnishing, but not the case.  I sand lightly before I dye or apply an edge coat or paint, so I know it is seeping into the leather.
I have tried using the glycerine bar and not.  I have waited days between steps, using and not using canvas, etc.
Can anyone provide a solution to this?  I truly do not understand what I am doing wrong or missing.  I use only vegtan, bridle and harness leather.
Cheers and have a nice weekend!
Edited by HondoMan
I ditched edge coat after having it come off a couple spots.
So back to my old routine with a bit of an addition.
Dye the edge.  I use Feibings Pro Oil Black.
Burnish with Tokonole.  I love this stuff BTW.
Apply a beeswax mix to fill in any small imperfections in the edge that did not burnish.
Two coats of acrylic finish.  I have a couple holsters on the table with a single coat of finish from tonight.  Black edges.  No rub off.
It sounds like you are testing the edges without adding a finish and expecting the color to hold.  If that's the case you need some type of finish to seal them.
You might want to give some black or brown Tokonole a go. I love that stuff. Here is an edge I did last night. That is two coats of brown Tokonole.
I should clarify. I did not dye the edge. I wet sanded the edge and then burnished with water only, followed by two coats of brown Tokonole.
  • CFM
I was afraid of having this problem. So far, can't say I've had it. But maybe it's because I never use wax. Just Edge Kote, sand with 400 grit with a light touch, second coat of Edge Kote, Tokonole and that's all.
Tried Resolene (50/50 with water) over the Edge Kote.  Better, but still rub off.
Tokonole over Edge Kote.... that's new.  Worth a wee try.  Odd with the Tokonole are no instructions or recommendations.  Found only one YouTube video.  Nothing more than burnishing, sanding and Tokonole and then wax.
I'm using mop and glo mixed 50/50 with water.  But you can do the same with resolene or any number of acrylic finishes.  They are basically the same thing.  I think you just need something that's going to seal the wax and dye up better.
