Members Lucasn7 Posted April 5, 2020 Author Members Report Posted April 5, 2020 On 4/3/2020 at 7:53 PM, CowboyBob said: Maybe it is stuck,you might want to tap the casting it alittle (carefully) w/a hammer & screwdriver. Indeed! It worked! I've moved the left assembly enough so that there is the same space between both needles and hooks. Now the next problem. I can feel (and hear) a bit more play in the gears of the left hook. I've moved the assembly to the left so there is more space between the angular gears. I've tried to loosen the screws on the left gear and gently tap it to the left but it won't move a bit. Any suggestions? Forward thanks! Quote
CowboyBob Posted April 6, 2020 Report Posted April 6, 2020 You have to "break" it loose too.Put a screwdriver carefully in the bottom of the groove & tap it to spin on on the shaft. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members shoepatcher Posted April 6, 2020 Members Report Posted April 6, 2020 Carefully as Bob says!!! glenn Quote
Members dikman Posted April 6, 2020 Members Report Posted April 6, 2020 If you've got a pin-point heat source you could try that to break it free. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Lucasn7 Posted April 14, 2020 Author Members Report Posted April 14, 2020 On 4/6/2020 at 2:03 PM, CowboyBob said: You have to "break" it loose too.Put a screwdriver carefully in the bottom of the groove & tap it to spin on on the shaft. That worked. Thanks to all of you who replied! Quote
