I have a chance to purchase either the singer 111w155 or a singer 111w154. I mainly make men's wallets which are usually 1/4" in thickness.
Can anyone let me know what the differences are between these two machines, and which one is better for making leather wallets also what's the maximum and minimum thread and needle size can these machines handle.
Thank you
Don A.
Hope this brochure helps ;)
But you never know if a vintage machine has been modified once...
Singer 111w Class Machine Brochure.PDF
Edited by Constabulary
Thank you, so im assuming this machine is a triple feed ?
Yes, but the 111w155 has more clearance under the feet, longer maximum stitch length and a higher speed top speed.
Posted IMHO, by Wiz
Thanks, unfortunately the singer 111w155 was sold, is the 154 worth purchasing for $450 ?
I also see a couple pfaffs for sale , is there a particular model that is good for sewing leather wallets, are parts readily available ?
145, 545, 1245 - flat bed  345, 335 cylinder arm - all triple feed machines.
  • 3 weeks later...
I found this singer 111w155, I think it's been painted, surface scratches appear to have black underneath but I'm not completely sure, the serial number is W1376837
Can anyone tell me how old it is and where it was maid
It sewed my leather very nicely using #138 thread on top
He is asking $600 for the head,table and consew clutch motor, it's been serviced and cleaned
Is this setup worth $600 ?
Seems to be from 1951.
This chart originally came from Keystone Sewing Machine Co. if I recall correctly
I would hold out for a machine with reverse.  If you plan to hand tie your first and last stitch, this feature may not matter for you.
