Rossr Posted January 7, 2020 Report Posted January 7, 2020 Just finished off the sheath today. Just some simple border work and stamped initials. Rolled deer skin lining. Wicket Craig skirting. I got off a bit stitching the belt loop in place but that's just me being critical. Made the knife too. O-1 tool steel. Antler handle in between damascus. I dont make my own damascu but i did shape it etch etc. Hope you all dont mind me continuing to post these up I realize sheaths dont change much just the carving.or tooling on them. Quote
Members YinTx Posted January 7, 2020 Members Report Posted January 7, 2020 I like them, keep sharing. The green on brown is a cool color combo, especially with the contrast stitching. I do have a question though. I made a butterfly sheath like for a knife I have, but everytime I try to return the knife to the sheath, it catches on the opening and slices the inside. How do you prevent this from happening? Also, the first stitch down the side but through the rolled edge: do you find it pulls the rolled leather in an unseemly manner, or is this a non issue? YinTx Quote YinTx https://www.instagram.com/lanasia_2017/ https://www.youtube.com/playlist?list=PLK6HvLWuZTzjt3MbR0Yhcj_WIQIvchezo
wizard of tragacanth Posted January 7, 2020 Report Posted January 7, 2020 That knife is sweeet! nick Quote Nick
Rossr Posted January 7, 2020 Author Report Posted January 7, 2020 (edited) 47 minutes ago, YinTx said: I like them, keep sharing. The green on brown is a cool color combo, especially with the contrast stitching. I do have a question though. I made a butterfly sheath like for a knife I have, but everytime I try to return the knife to the sheath, it catches on the opening and slices the inside. How do you prevent this from happening? Also, the first stitch down the side but through the rolled edge: do you find it pulls the rolled leather in an unseemly manner, or is this a non issue? YinTx Ok just my thoughts on the opening. When I put the knife in the first time it's usually just a shade damp from stamping. So it sets it open some I let it dry over night . Attached are pics of the opening and side view of this one. In reality I can still easily miss and slice the liner. I sliced a pouch sheath a bit one time no liner just the vegtan when I took my eyes off it as I pushed it in while it was on my belt. So I think my answer is make sure the opening is enough, still needs to be tight though. Then it's a matter of staying vigilant when replacing the blade. In regards to the roled lining stitch. That is tricky I have had it squish too much. I now try to center it best I can which helps. I am also not sure I need to go that high but the welt is up ther so I want a good closure. Remember I am using a needle awl machine so maybe the pressure on the foot causes issues too. I seem to like too finish there rather than start which seems to help but may just be me. On the belt loop the reason the stitch is off I got out on the rolled part and didnt want to run down just that and get both a weaker hold and that squish effect. So I chose to move back in and catch the skirting leather too. Hope that all makes sense 13 minutes ago, wizard of tragacanth said: That knife is sweeet! nick Thanks Nick Edited January 7, 2020 by Rossr Quote
Members Retswerb Posted January 7, 2020 Members Report Posted January 7, 2020 Keep posting, I love seeing them. I’d say this is one of the nicest rolled edges I’ve seen. Quote
Rossr Posted January 7, 2020 Author Report Posted January 7, 2020 1 hour ago, Retswerb said: Keep posting, I love seeing them. I’d say this is one of the nicest rolled edges I’ve seen. Will do and Thanks Quote
Members Tugadude Posted January 7, 2020 Members Report Posted January 7, 2020 Nice work Rossr. I have always admired folks that had multiple skills and the ability to combine them. Is that Damascus steel I see? Based upon the shape of the handle I'll be it fits perfectly in the hand. Quote
Rossr Posted January 7, 2020 Author Report Posted January 7, 2020 2 minutes ago, Tugadude said: Nice work Rossr. I have always admired folks that had multiple skills and the ability to combine them. Is that Damascus steel I see? Based upon the shape of the handle I'll be it fits perfectly in the hand. Thanks. I think I just like making and learning new things. I just keep trying. Yes that is Damascus. I have never tried to make damascus that's a whole.other set of skills. I think I bought that from Alabama damascus. Its sold as a flat sheet you can then cut shape and in this case I made the bolsters. Lastly I etched it in acid to bring the pattern out. Ross Quote
Members Tugadude Posted January 7, 2020 Members Report Posted January 7, 2020 2 hours ago, Rossr said: Thanks. I think I just like making and learning new things. I just keep trying. Yes that is Damascus. I have never tried to make damascus that's a whole.other set of skills. I think I bought that from Alabama damascus. Its sold as a flat sheet you can then cut shape and in this case I made the bolsters. Lastly I etched it in acid to bring the pattern out. Ross Very cool. I didn't know about the acid process. I guess I assumed that the grinding and/or polishing would suffice. Have you attempted to use the Damascus for a blade? I saw some that had been done by I think a Japanese or Korean manufacturer that looked beautiful. Quote
CFM chuck123wapati Posted January 7, 2020 CFM Report Posted January 7, 2020 Both a very well done, I love a flat grind blade. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
