Members Carnivore Posted January 10, 2020 Members Report Posted January 10, 2020 Tri-Fold wallet I just completed. I used a template from "Make Supply". The leather is Tandy croc embossed veg-tan 4-5oz. Stained with Eco-Flo stain in Forest green. Stitched with 6mm Tiger thread. Quote
Members kiwican Posted January 10, 2020 Members Report Posted January 10, 2020 I like that. How do the edges burnish up? Or did you use an edge paint? Quote
Members Carnivore Posted January 10, 2020 Author Members Report Posted January 10, 2020 35 minutes ago, kiwican said: I like that. How do the edges burnish up? Or did you use an edge paint? Edged burnished up nicely just using diluted dye and wooden burnisher. Quote
Members sinpac Posted January 11, 2020 Members Report Posted January 11, 2020 I made one of those from the same template. Pretty decent design. The only thing I noticed was the T-slot template on the curved pocket was cut on a 90 degree which leaves a small gap going into the other pocket. all you need to do is cut the T-slot to the same curve. I showed my in the patterns section. As far as your wallet nicely done. Chris Quote
