Members bulldog7 Posted January 20, 2020 Members Report Posted January 20, 2020 I am brand new to leather working and have a question about holes. I sewed my first little project and I did not do a good job of punching holes. I have the tool to scribe the line on the leather and a pronged chisel and then used an awl but the holes were inconsistent not nearly neat and clean enough. What methods and tools do you recommend for crisp clean hole punching? Quote
Contributing Member fredk Posted January 20, 2020 Contributing Member Report Posted January 20, 2020 I like to use a multi-pronged chisel which will punch many holes at a time. They can be bought with 1 prong, 2, 4, 6, 8 and 10. I only use an awl now to open up the punched holes if I need to. Another tool I use more frequently is a pliers type with four teeth which punches 4 holes at a time, from both sides. Whichever you use, with a multi-pronged/toothed punch, put the first 1 or 2 teeth into the last 1 or 2 punched, this will help keep the line straight. Pliers type; Stitching punches Quote Al speling misteaks aer all mi own werk..
CFM chuck123wapati Posted January 20, 2020 CFM Report Posted January 20, 2020 the multi pronged chisels work very well and are probably the easiest to get good results with. there are other ways also I would also suggest as you are new to leather working to get on the Tandy website they have a ton of free ebooks on leather working that literally covers everything you will need to get started. https://www.leathercraftlibrary.com/account/signin?ReturnUrl=%2Fcategory%2F79%2Febooks%3Fpagenum%3D1 Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members zuludog Posted January 20, 2020 Members Report Posted January 20, 2020 (edited) Search YouTube for 'saddle stitching'; there are several videos; watch a few of them and you'll see how it's done This one is good - 'How to Hand Stitch Leather - Saddle Stitch Tutorial' by JH Leather Saddle stitching - sometimes called two - hand or double - hand stitching is so common in leatherwork that if you watch almost any item being made, the video will show saddle stitching to some extent As you are new to leatherwork does that mean you have a new awl? A lot of the time & effort, and therefore the cost involved in making leatherwork knives and awls is taken up with the final sharpening and polishing. So it is very common for the makers to give these tools only a basic finish, and you are expected to do the final sharpening & polishing yourself. That keeps the price down; it is only the top end makes, say $50 or more for an awl that you can use straight out of the box. Search YT for 'sharpening an awl', there are several videos. A well sharpened awl blade should slide through the leather like butter, with very little effort; watch the videos by experienced leather workers and you can see that. A blunt awl will require more effort; distort and bend the leather because the tip of the blade pushes against the leather but does not penetrate it easily, resulting in ragged, uneven holes If you have bought the 4-in-1 awl sold by Tandy and others, well that isn't very good. Use the round/scratch awl blade, but you'll be better off in the long run if you buy another, better, diamond awl Edited January 20, 2020 by zuludog Quote
wizard of tragacanth Posted January 20, 2020 Report Posted January 20, 2020 (edited) A picture of your results may help us diagnose your problem. nick Edited January 20, 2020 by wizard of tragacanth Quote
Members Tugadude Posted January 20, 2020 Members Report Posted January 20, 2020 4 hours ago, chuck123wapati said: the multi pronged chisels work very well and are probably the easiest to get good results with. there are other ways also I would also suggest as you are new to leather working to get on the Tandy website they have a ton of free ebooks on leather working that literally covers everything you will need to get started. https://www.leathercraftlibrary.com/account/signin?ReturnUrl=%2Fcategory%2F79%2Febooks%3Fpagenum%3D1 Glad you shared that as a lot of folks don't know about the free stuff. Quote
Members Tugadude Posted January 20, 2020 Members Report Posted January 20, 2020 5 hours ago, bulldog7 said: I am brand new to leather working and have a question about holes. I sewed my first little project and I did not do a good job of punching holes. I have the tool to scribe the line on the leather and a pronged chisel and then used an awl but the holes were inconsistent not nearly neat and clean enough. What methods and tools do you recommend for crisp clean hole punching? You indicate you have a pronged chisel. What type? It might be the type that is designed to punch through the leather. If not, invest in some. Since you are "brand new" as you say, I wouldn't buy an expensive set just yet. You can purchase entire chisel sets on fleabay very cheaply. Or there is Tandy, Rocky Mountain Leather, Springfield Leather, etc. They all sell chisels similar to the ones that Fredk showed. Personally, that is what I would recommend beginners start with. I do sometimes use an awl, but honestly, I can do anything from fine work like a watch strap all the way up to a briefcase with chisels and get great results. Even experts such as Nigel Armitage says chisels can help beginner and intermediate leather workers to get very good results. All chisels or irons aren't created equal. Mr. Armitage reviews many of them, like around 20 or so, on his youtube channel as well as in print on his company website, Armitageleather.com Quote
CFM Hardrada Posted January 20, 2020 CFM Report Posted January 20, 2020 (edited) Like Jo from JH Leather, Terrick stitches using an awl: that's the traditional method, because back then the stitch holes used to be marked (pricked) with a pricking iron but actually pierced with a diamond awl. You don't need an awl if you punch your leather with stitching punches, like many of us do: this latter method is easier. Note that you might still need to use an awl if you're stitching thick leather or several layers that amount to a total weight greater than ~8 oz. When you have several layers, it's not difficult to punch the holes slanted no matter how perfectly straight your marked line is. If you're using a light mallet like the yellow poly mallet from Tandy, you will require several whacks to pierce thick leather or several layers and the chances of having this problem will increase. I strongly recommend that you get a 24- or 32-ounce poly mallet from Brarry King: less whacks and less bounce. RE: chisels: you can get top quality brand new chisels from goodsjapan.com. I'd recommend the Seiwa diamond chisels: two sets: one 2-prong and one 5-prong of each 3 mm and 4 mm distance between tips. Whilst you're at it, grab a Kyoshin Elle or Craftsha diamond awl that comes sharper than Tandy's. Edited January 20, 2020 by Hardrada Addenda Quote
CFM Hardrada Posted January 20, 2020 CFM Report Posted January 20, 2020 Here: Goods Japan stitching chisels and nippers They sell the kind of nippers fredk mentioned: these are very useful when you need to punch holes on the edge of leather that's been folded 90°, such as when you're doing three-piece cut edged gussets. Quote
Contributing Member fredk Posted January 20, 2020 Contributing Member Report Posted January 20, 2020 Those nippers are kinda expensive. I bought mine for under £10. They've gone up in price but can still be bought for under £15 ($18 or so?) Quote Al speling misteaks aer all mi own werk..
