Members Nert Posted January 30, 2020 Author Members Report Posted January 30, 2020 1 hour ago, Rockoboy said: Another factor to consider when cutting some materials that are less desirable (like chrome tan leather, PVC, polycarbonate etc) is the gas given off can coat the lens. This coating will etch the surface thereby reducing the effectiveness of the machine. This coating and the damage will require the replacement of the lens. Yeap i know it :) but i dont cut it, Just engrave some letters and numbers 2 hours ago, LatigoAmigo said: Sure... Thank you :) Quote
Contributing Member LatigoAmigo Posted January 30, 2020 Contributing Member Report Posted January 30, 2020 3 hours ago, Rockoboy said: Another factor to consider when cutting some materials that are less desirable (like chrome tan leather, PVC, polycarbonate etc) is the gas given off can coat the lens. This coating will etch the surface thereby reducing the effectiveness of the machine. This coating and the damage will require the replacement of the lens. This has not been my experience when cutting leather. My laser cutter has an air assist pump that forces fresh air through the nozzle when in operation, and a ventilation system that removes the smoke from the cutting area. The lens is located 2+ inches away, up inside of the laser head, much removed from the surface of the material being cut. None of the smoke I make from cutting leather reaches the lens, and I have never encountered the issue of etched lenses. I'm only speaking about leather (chrome-tanned and otherwise), as I can't speak to PVC or poly-carbonates related issues. Quote
