Introductory pricing through the month of March on the Horse Creek Leather Works belt hole alignment/marking system. Regular price $74.95 – introductory price $59.95 including shipping to the lower 48. The system consists of 2 jigs that center and space your holes perfectly and quickly every time. The tip and buckle end jigs both have adjustable stops with the tip end marked at 6 ½”, 7”, 7 ½”, 8”, and 8 ½” from the center hole. The tip end has two versions, one with hole spacing at ¾” on center and 1” on center. Simply place over the belt and slide up to the belt end, close the sides against the belt, mark with the provided marking tool or your punch and you have perfectly spaced and centered holes. We call it the FTM-CTM (faster than measuring-cheaper than machine). You can order by credit card at https://hclw-belt-tool.square.site They can also be customized at extra cost on a case by case basis.
email: butch@horsecreekleatherworks.com
phone 828 528 1831
Thank you
Edited by Northmount
fixed URL
link doesn't work, but I'd love to check it out
I clicked the link and for an error message as well. If you remove the period (.) at the end of the link then you'll get through. Here it is: https://hclw-belt-tool.square.site
Hope this helps.
