Members CastleLeatherWorks Posted April 7, 2020 Author Members Report Posted April 7, 2020 37 minutes ago, LatigoAmigo said: I create all of my own patterns using Adobe Illustrator. I spent some time studying graphic design, where I learned a few "tricks of the trade." On Craig's List, I found a 100-watt CO2 laser located nearby. It wasn't what I would have preferred, but it fit my pocketbook. The work area of the bed measures 20 x 30 inches. There is a bit of a learning curve when cutting various types of leather, and then there is the smell. I just installed a fume extractor to eliminate offensive odors. ahh that's cool I actually went to graphic design school back in the early 2000s and dropped out shortly after lol (to much history and English and not enough graphic design) I was actually just going to get the monthly adobe subscription so I could do some design work in illustrator. 20x30 is a pretty decent work envelope.. I was actually looking into the laser cutters a while back but I never pulled the trigger. they seem pretty handy for all sorts of things not just cutting leather but I think right now a bell skiver would be the most beneficial for my needs. appreciate the convo and help ! Quote
Members DomsLeather Posted April 7, 2020 Members Report Posted April 7, 2020 2 hours ago, LatigoAmigo said: I create all of my own patterns using Adobe Illustrator. I spent some time studying graphic design, where I learned a few "tricks of the trade." On Craig's List, I found a 100-watt CO2 laser located nearby. It wasn't what I would have preferred, but it fit my pocketbook. The work area of the bed measures 20 x 30 inches. There is a bit of a learning curve when cutting various types of leather, and then there is the smell. I just installed a fume extractor to eliminate offensive odors. I have used some laser cut and etched leather before. I hated it because of the burnt hair smell. They were keychains cut out and logo lasered on them. I put the rings on them and riveted them. Does the smell fade? I got them from the laser guy right after he cut and engraved them. Quote
Contributing Member LatigoAmigo Posted April 7, 2020 Contributing Member Report Posted April 7, 2020 15 minutes ago, DomsLeather said: Does the smell fade? It does, but I help it along as much as I can. First I coat the leather with a paste I make that I found on the site here. It is for braiding (Ivory soap, lard and water), but ends up like a very light saddle soap. I apply it before lasering and it picks up much of the residue that might find its way onto the surface of the hide, then wipe with a microfiber cloth. On the edges I use foaming saddle soap and work it in, then wipe with a microfiber cloth. Then I seal the edges with Tokonole edge paint. It applies easily, is water based and dries quickly. Two coats of that and I'm done. The smell is cleaned off of the surface, and any residual smells are sealed into the edges. If I do any engraving, I rub Fiebing's Antique Finish into the lasered area, and let the leather soak it up, then rub the excess off very gently. Laser engraving creates an image that is very fragile, so I don't rub it in, but I don't engrave often, so I have limited experience with it. Hope that helps. I must add that I don't cut veg-tanned leathers, only chrome and combo tanned (like latigo). Quote
Members DomsLeather Posted April 7, 2020 Members Report Posted April 7, 2020 Thanks for the response. This was raw vegtan. It was horrible. Quote
Members shripud Posted April 15, 2020 Members Report Posted April 15, 2020 On 4/7/2020 at 10:18 AM, CastleLeatherWorks said: So this is my first attempt at making a bag of any sort. I’m actually really pleased with how it turned out. I’m calling this a prototype because I plan on making more with nicer leathers. While this looks pretty decent there’s quite a few scars on the leather and while it worked for this bag that’s not really the look I’m going for. Also I need to tweak the pattern a bit. And I need to make a strap just waiting on some leather to come in. The bag is made of 2.5/3.0oz European veg tan from Tandy. Stitched with twist 0.45 cream linen thread and I used some cheap 5mm pricking irons from Amazon. The liner is some sort of suede from an old jacket liner I believe (my aunt gave it to me when I told her I was making leather goods) I got the gold hardware from sav-more leather in Downtown LA. I’d really like to hear what you think or maybe offer some insight. I wasn’t sure if I was supposed to glue the seams before sewing ( I didn’t ) also I forgot to undo the zipper A little bit before closed it up so that was a total pain trying to get the zipper open so I could flip it. Here’s a lot of pics =) Thanks for looking ! Hello, its a great effort and the bags looks very good. 1. Corner Correction. In turned type of bags the corners present a small challenge. The corners of your bags are puffed out and not neatly tucked in. A work around for this is that you can give a row of stitches lower than the existing stitches while your bag is flipped inside out as you would to make this kind of turned in bag. 2. Piping Installation To make the the transition from the face of the bag to the gusset and from the back of the bag to gusset a bit smoother its suggest to add a piping wrapped in the article's leather. Just makes it a little neater and professional. Quote
