As Jimi said - to me it also looks like the top tension unit is missing. I only can see the thread loop but not the tension unit.
That's what I started to say, but it looks like the angle of the photo is playing tricks, I can see a part of the top tensioner guide.
My top tensioner was missing when I first got mine, it took a while to work out why it would not sew correctly.
Bert.
Edited by Bert51
4 hours ago, Bestedreng said:
Looks very similar to yours!
This is a photo i looked for and it is from here on leatherworker, i do not have this machine but one similar without the kick foot. was the 1st tension assembly moved for a specific reason??, I think it´s proper place is on the top left corner of the face plate?. And remember you have to go around the second tension pully  1 1/2 times.
I dont know why the 1st tension assembly is located differently, but it doesn´t seem to have been moved. Thank´s for all your efforts! I know got the machine to work properly. I got the stuck part moving with some heat and oil, and have now adjusted the hook to time with the needle a couple of millimeters earlier. It solved the problem with skipped stitches.
Good to hear you have solved the problem, :thumbsup:
 To me it looks threaded wrong from the thread coming out of the top tension assembly to the bottom thread tension unit.  Opps.  previous picture the threading looks correct.
glenn
