Members Atlr9640 Posted April 24, 2020 Members Report Posted April 24, 2020 Hello guys, I have been struggling to make a raise leather key ring it’s something I’ve been wanting to make for a while and I can’t seem to get it right. I’ve attached pictures of what I’m trying to go for and my current process is this; cutting two straps to match the keyring hardware (in my case 2cm) then adding a strip of leather in the middle of one panel much narrower than the 2cm strip and gluing on top the last strip then using a bone folder to form the leather and get that raised effect. my problem is that the top strap is too narrow once glued so i adjust the top layer to compensate but I still can’t get a straight line and my raised keyring looks all wonky and distorted. any help and way of making them would be a huge help!! Quote
terrymac Posted April 24, 2020 Report Posted April 24, 2020 Cut one piece slightly larger, and trim to fit after gluing the the raised piece. Hope this helps Terry Quote
Members Alexis1234 Posted April 24, 2020 Members Report Posted April 24, 2020 I make the bottom piece the size I want, then I take a filler piece and bevel the edges of it with a french edger. Top piece is slightly larger. Quote
Members Atlr9640 Posted April 24, 2020 Author Members Report Posted April 24, 2020 2 hours ago, terrymac said: Cut one piece slightly larger, and trim to fit after gluing the the raised piece. Hope this helps Terry Thank you terry I will definitely give this a go, Aleks 1 hour ago, Alexis1234 said: I make the bottom piece the size I want, then I take a filler piece and bevel the edges of it with a french edger. Top piece is slightly larger. I’ll try doing that to cut the exact measurements I want, only thing I’m worried about is with the bottom piece covered how to accurately cut the excess Quote
Members Alexis1234 Posted April 24, 2020 Members Report Posted April 24, 2020 I make the piece up, glue , use bone folder and tacks if need be and when it's dry I'll trim it.I personally use a round knife to trim, but whatever works for you- razor blade, scalpel, etc. For straight raised strap work I add 1/4" to the top piece- but don't hold me to that, it depends on what your doing and I haven't been at this that long!. Pics of 1/2" raised straight strap and a shaped martingale drop. I'm sure those with more experience will chime in. Quote
Members Retswerb Posted April 25, 2020 Members Report Posted April 25, 2020 @Atlr9640, make another attempt and post a pic of the results. Much easier to give advice if we all can see what’s going on with your process. Quote
Members Atlr9640 Posted April 25, 2020 Author Members Report Posted April 25, 2020 (edited) So here is my first attempt, I definitely think as @Alexis1234 said increasing the size of the top strap, so I wanted to edge paint but because the way the straps lined up I had to bevel and burnish to hide my mistakes. excuse my stitching in the pictures I rushed it to see how it would turn out ! Edited April 25, 2020 by Atlr9640 Forgott text to add Quote
