Members wulfjh Posted July 7, 2020 Members Report Posted July 7, 2020 I’m new to sewing and struggling with this new sewing machine. My thread is getting wrapped around the bobbin holder under the sewing machine. Is there an adjustment I can make here or something I need to do to correct this? Thanks in advance for anyone who could give any advice. Quote
ljk Posted July 7, 2020 Report Posted July 7, 2020 Hi I have had one issue like this on the 206. The hook assembly would sometimes jam even on 92. Suggest try 69 thread. If it works that's your problem. Suggest you ask one of our dealer about new assembly. I have had some luck running valve grinding compound to polish assembly. Good luck Lynn Quote
Members Constabulary Posted July 7, 2020 Members Report Posted July 7, 2020 (edited) hard to tell from the picture but maybe t you have to adjust the bobbin case opener (mentioned in the manual) maybe gap between bobbin case opener / thread release finger and hook notch is too small. EDIT: Edited July 7, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
CowboyBob Posted July 7, 2020 Report Posted July 7, 2020 7 hours ago, wulfjh said: I’m new to sewing and struggling with this new sewing machine. My thread is getting wrapped around the bobbin holder under the sewing machine. Is there an adjustment I can make here or something I need to do to correct this? Thanks in advance for anyone who could give any advice. What size thread is this? And are you SURE it is threaded correctly & don't forget the hold your needle thread the first 3 stitches. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
