Rossr Posted July 27, 2020 Report Posted July 27, 2020 Last year I had made up a couple coasters similar to this. The back side had a brand mark and the front I carved with a craft aid wildlife template animal. Since I just made a stitching pony I figured I should make and finish the set. Having 2 more brand marks. I choose a. Rabbit and moose head to carve, dyed them and then laced the black lace double loop and brown lace round braid. Always open to improvements Quote
Members Retswerb Posted July 28, 2020 Members Report Posted July 28, 2020 Putting that pony to good use! Keep up the good work. Quote
Members Alaisiagae Posted July 28, 2020 Members Report Posted July 28, 2020 Those look very nice! Love the lacing/braiding - was it difficult to do that since the coaster edges are all round? Did you cut the coasters out? I just buy coaster blanks, because I don't think I could cut a perfect circle. Quote
toxo Posted July 28, 2020 Report Posted July 28, 2020 3 minutes ago, Alaisiagae said: Those look very nice! Love the lacing/braiding - was it difficult to do that since the coaster edges are all round? Did you cut the coasters out? I just buy coaster blanks, because I don't think I could cut a perfect circle. If you google circle cutters there'e are lots of them just make sure you get a more robust one. not just for card. The one I use was very inexpensive. If you don't mind a hole in the middle it's even cheaper. Quote
Rossr Posted July 28, 2020 Author Report Posted July 28, 2020 (edited) 1 hour ago, Alaisiagae said: Those look very nice! Love the lacing/braiding - was it difficult to do that since the coaster edges are all round? Did you cut the coasters out? I just buy coaster blanks, because I don't think I could cut a perfect circle. First off Thanks. I happen to have a circle die and a clicker press so that makes it easier. I have used a circle template made of thick I think acrylic and an exacto which works ok but u have to be careful not to cut the template and stay on track. As far as the lacing its not.too bad to use a lacing chisel to go around it. You can always use a single point one too if needed. I was able to use a four prong one for the moose and a slanted three on the rabbit. Edited July 28, 2020 by Rossr Quote
Rossr Posted July 29, 2020 Author Report Posted July 29, 2020 6 hours ago, Carl said: Outstanding! Thanks carl Quote
