Members Bananaman Posted August 2, 2020 Members Report Posted August 2, 2020 No experience with Servo motors but it does not sounds good :-) . It is brand new one, just installed and on low speed is making some grinding noises which will increase with load. On speeds over 700rpm noise will almost disappear. Is this normal? Another thing , min speed is 400rpm and is changing in 100rpm incremments or so, no smooth change, it is 400 or 500. Nothing in between. Not sure is this normal or not. Cheers Quote
Members dikman Posted August 2, 2020 Members Report Posted August 2, 2020 A lot of the generic servos tend to have that characteristic low speed "issue". That's one reason for fitting a small pulley on the motor and a speed reducer. As for the noise, does it make it with the sewing machine belt removed? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Bananaman Posted August 2, 2020 Author Members Report Posted August 2, 2020 On 8/2/2020 at 2:09 AM, dikman said: A lot of the generic servos tend to have that characteristic low speed "issue". That's one reason for fitting a small pulley on the motor and a speed reducer. As for the noise, does it make it with the sewing machine belt removed? Expand No, it does not make noise with belt removed. cheers Quote
Members dikman Posted August 2, 2020 Members Report Posted August 2, 2020 Hmm, was the sewing machine working ok before (I assume it had a different motor fitted)? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Gregg From Keystone Sewing Posted August 4, 2020 Members Report Posted August 4, 2020 Sounds like excessive belt tension. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Bananaman Posted August 9, 2020 Author Members Report Posted August 9, 2020 On 8/2/2020 at 5:45 AM, dikman said: Hmm, was the sewing machine working ok before (I assume it had a different motor fitted)? Expand Yes, no problems with clutch motor. Nice and easy turns with hand Quote
Members Bananaman Posted August 9, 2020 Author Members Report Posted August 9, 2020 On 8/4/2020 at 1:15 PM, Gregg From Keystone Sewing said: Sounds like excessive belt tension. Expand Exactley , only there is no excessive belt tension. Belt was set up on “ just grubbing” tension. I did try it with belt off the machine, holding with my hand and as soon as I put bit of pressure noise will start. I could live with bit of noise , but, in my experience, motors with “ grinding noises” do not last long unless it is “normal” . cheers Quote
Members dikman Posted August 9, 2020 Members Report Posted August 9, 2020 Hmm, none of my servos make much noise. Is it the same whether it's run flat out or very slow? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members RyanFromHolland Posted July 3, 2021 Members Report Posted July 3, 2021 I wondered If you were able to solve it? Because I have the exact same sound! Just installed, new out of the box!I have no comparison nor experience with these motors,, but this sound is worrying me too. Did you found a solution/anwser? Quote
